About DAC
JediMa
Italy
I have at the moment a Topping E50 with sounds very well but has limited features, like BT and such, I was wondering if SMSL DO100 PRO is a good option or I should look for something else with a budget of 250?
Seems like a fine option. What features are you looking for?
Beside to be full balanced (I would use it with SMSL H400) Well more connectivity options like Bluetooth, optical, better interface - menu - Streaming
Beside to be full balanced (I would use it with SMSL H400) Well more connectivity options like Bluetooth, optical, better interface - menu (Topping stuff is quite confusing)
The SMSL DO100 Pro display is only three seven-segment elements. If you want an easy menu, look for another kind of display.
And so which one could be a better option?
That depends on what inputs you want. The SMSL M300SE and RAW-MDA1 may work better. Take a look at the manuals.
RAW-MDA1 looks like a very interesting option, that you know is even better than Topping E70? they have exactly the same price here
Is the menu in the E70 different from the one in the E50? Otherwise, you just gain bluetooth input and volume control on the device.
