This is what I like to use: https://www.newark.com/legrand-wiremold/ul205bc/power-outlet-strip-8-outlet-15a/dp/95F1273
I have been using this one. In addition to more outlets than I'll need, it has spacing between the outlets to accommodate larger wall warts.
Heavy Duty 20 Outlet Commercial Power Strip | Buy Direct & Save! (falconerelectronics.com)
Hi sorry i have a question about this picture The earth terminals are not connected Is this ok for safety ?... And some people talk about "star connection" , something like this:
Without any noise filtering. They say that the can hear "better sound", with these power strips, without any filtering.
I would like to upgrade my 2 general use (and cheap) Legrand power strips:
The marble obviously makes it superior. Marble roofing was used on the Greek temple of Zeus. Obviously again Zeus could shoot thunderbolts and they used marble. I don't think that was accidental. When thunderbolts come for your gear, they'll avoid anything marble just because of this principle.Doesn't hold a candle to this, though...
Hi thank you very much indeed for your kind and helpful advice.That picture is an example of 'Star Wiring' only, none of the other wires are shown.
In a completed unit, yes the Safety Ground/Protective Earth wire NEED to be connected.
It's doubtful that there are any gains from this internal 'Star Wiring'.
It's also doubtful that the completed unit is 'UL' (or other safety org.) listed.
is that specifically for USB chargers? the spacing does look like it (not to forget the current draw from a single outlet...)I bought one of these a few years ago...
Tripp Lite 24 Outlet Bench & Cabinet Power Strip, 72 in. Length
I used those on the electronic repair bench riser tops (front edge) I had at my shop decades ago. Were ideal, tho not nec living room friendly.is that specifically for USB chargers? the spacing does look like it (not to forget the current draw from a single outlet...)
