120 hz hum-- not from my audio gear but from my house-- what to do about it?
Doodski
@restorer-john what do you attribute this hummmm to? I think if the power line is active as in in-service then they must maintain ground reference albeit at a lower power rating.
pseudoid
...Use a transformer to obtain mains,...
The story of the 3 large size audio transformers used in the 1960s MCIntosh power amplifiers (e.g. MC275) were potted with a compound that contained nasty (carcinogen?) chemicals used to prevent any 60Hz hum caused by the close-coupled winding that may vibrate... One of the reason that was cited (as I recall) for their discontinuation. In the early 1980s, McIntosh broke the news that a pallet of these transformers where found in some warehouse and that they would make a limited quantity of SeriesII MC275s.
While working for on some military ship-borne massive communication suite, the 400Hz power required for energizing parts of the RF power systems in a shielded chamber, the needed MAINS' power-factor correction coils that were mechanically/galvanically isolated from the chamber but would sing so loud (~102dB/A), live qualification testing could only be achieved after-hours and the technicians (w/headphones) were only allowed to stay in the SCIF labs for no more than 4 hours per day.
That 400Hz :mad: hum continued for three months straight, but we were lucky no one had gone postal on us!
Doodski
Fascinating stuff for sure. Is this something you worked on with the 400 Hz mains?
Gringoaudio1
Calgary Alberta Canada
So so-called ‘hum’ that plagues people world wide seems to be around 40-50 hz. 120 hz has to be related to the 60 hz grid somehow. But why 120 and not 60 is even more curious.
ivanj
I continue to be plagued with an ever present 120 Hz, ambient, hum of unvarying loudness inside and outside my new house and , indeed, all around the neighborhood. Flipping off the main circuit breaker to my house does not change this in any way.
I'm left with the theory that this is mains hum originating in the power lines around my house and throughout the neighborhood.
What do you mean by 'all around the neighborhood'?
Who was the builder who built the development, eg., Lennar? Do you have a new home warranty?
It's possible the power lines were never installed properly...you might (a big might) be able to find out if the power utility or whoever inspects them signed off on the installation.
pseudoid
? Wouldn't "improperly installed powerlines" cause 'noise' (arc/spark) rather than "hum"?
I have never heard of (or seen) above-ground powerlines which showed to be 'vibrating' at frequency-of-operation or its harmonics... but I don't get out much anymore.
Trying to find the location of the transformer(s) serving the community's powerlines may lead to a missing clue. ymmv
Timcognito
NorCal
I read once DXers get a post hole digger, a bag of ferro-cement and 4 ft piece of re-bar and dig a deep hole, mix and fill the hole with cement and rebar. After it dries the ground wire from a dedicated circuit(s) is run to the re-bar for dead quiet operation.
Disclaimer: I'm a ME
Timcognito
NorCal
Old phase forward dimmer switches are notorious for sending hum everywhere.
Gringoaudio1
Maybe walk around the neighborhood in a grid pattern recording the volume of the hum to help locate the source. Correlate to location with GPS.
JSmith
Algol Perseus
JSmith
sam_adams
JSmith
The first link is nonsense. The 'buzzing' that one hears near HT lines—10, 12, 15 KV or higher—is caused by arc-over on the insulators due to the moisture content in either the air—think heavy fog, drizzle, light rain—or actual liquid water or dirt/debris on the lines and poles. It's more of a crackling/sparking/arcing noise than a hum—and in dry weather—usually indicates that your local electrical utility hasn't cleaned the insulators in a long time. The local utility in my area has specialized trucks that have a high pressure water jet system that blasts the accumulated dirt and debris from the HT line insulators to prevent that specific situation from occurring since it causes an actual loss in delivered capacity.
The second link involves ground loops. The author obviously has never heard an angry three-phase motor that was wired wrong or a buck/boost transformer wired out-of-phase. Hum is the 50/60 Hz fundamental. Buzz is the odd order higher harmonics. Bill Whitlock has explained that, ad nauseam, for decades.
Andolink
Andolink
Scottsdale, AZ
Interesting. Would the hum be present even with the lights turned off?
Timcognito
NorCal
No but things that use transformers have similar issues. Shut all breakers off and then turn them on one by one only to see if it is a isolated issue.
pseudoid
Thank you for the articles but both are quite hard to swallow (as explanatory), yet some included factoids are valid.
I think once the EXACT definition of hum (60Hz/120Hz?) is made we can further discuss the source but once hum becomes universal word covering every type of noise (thru out the RF spectrum); then, we got ourselves a whole different argument that should be left for another thread.
This "hum" we are attempting to discuss from different perspectives has been referenced (in your links) as either the magnetic component and/or the electrical field of "power" we can call the 50-60Hz (+few harmonics) MAINS.
Granted the 'hum' due to magneto-striction effects of close-coupled wiring (as in a live coil/xfrmr) is a valid source; yet, to blame straight-line MAINS wiring overhead for the source of the this particular type of 'hum' is a big reach. imo
Your links also 'speak' of speaker effects; as if a straight-wire that is not exactly tuned to the wavelength/partial of the source frequency (MAINS=50Hz or 60Hz) that cannot be expected to sing like a tuned port.
That dude @sam_adams [who always seems to have migraine headache;)] makes sense to me more than anything those two articles lay out.
Andolink
Andolink
Scottsdale, AZ
With the main breaker shut off, i.e. all power to the house - right?, the hum is still there exactly as with the power on.
Timcognito
NorCal
Everything off where is it coming from, the air?
pseudoid
No, @Timcognito, it is not what a GroundFaultInterrupter does either! Literal or figurative.:eek:
If not by air, and not by ground... then, it must similar to what @thegeton suggested elsewhere:
"Catfish, anyone?":rolleyes:
antcollinet
UK/Cheshire
I've often heard hum/buzz from HV power lines. Actually from the pylons rather than the lines.
It would not be a big surprise if the magnetic field generated by up to 4000A moved some stuff at mains frequency.
pseudoid
FWIW: Someone did the math, already:
This is the only explanation I can think off : Lorentz force due to earth's magnetic field
Let's do a rough estimation:
Let's say we have some power line at 1000A (should be ok for 100mm^2 wire), 200 meters between towers.
F=200 meters * 1000A * 40 microteslas (some average Earth's magnetic field) = 8 newtons (Not looking at angle at the moment, depend on position & location)
While 8 newtons itself is not much to significantly move heavy wires at 50/60 hertz (this sample wire would weight ~180kg), if line have any mechanical resonance at multiple of 50/60 hertz, vibration will amplify and will be significant to make audible sound.
From <https://physics.stackexchange.com/questions/12629/why-do-power-lines-buzz>
Is this more plausible than the catfish?
Andolink
Andolink
Scottsdale, AZ
Exactly! That's the thing that's driving me batty. What's the source of this hum?? My wife hears it too so it's not my tinnitis or one sided hearing loss. In fact, my hearing problems exacerbate my already acute sensitivity to background noises of all sorts, hums, autos, sirens, airplanes, etc., etc. And, as I said, when I walk down to the end of my street or anywhere else in my neighbohood, if the ambient noises are relatively low, there's the hum.
