dasdoing
It's not a standard, streaming services are lately tending to adopt to - 18 LUFS so called ripple gain 2.0 which is again wrong. EBU R128 has a largest limit - 23 LUFS and there for highest headroom for bad materials from golden days of loudness war's. It's to much of a SPL reduction but as stated before it can be easily gained back with peak normalisation. In the end who cares about master levels used when mixing if EBU R128 can normalise them correctly and you can adjust them to yours desired listening levels with ISO 226 2003?
Neither is ISO 226 2003 magical nor it translates universally to all speakers but it makes a big difference especially when you want to listen at moderate to low levels. On the other hand even EBU R128 - 23 LUFS limit isn't enough for really really horrible exaggerated mixes (made to sort of sound better on something like mobile phone speaker).
Example of such:
So advice is skip such entirely.
Seriously instead adopting EBU R128 and ending loudness war's we instead have half way in between and half cut non standard solution's.
loud genres actually don't care for streaming standards. the "standard" for those are -9 LUFS or even higher. they don't care if streaming services pull them down, because it's all about the density of the mix. electronic music using 14dB or even more of headroom just wont sound right
