Topping A70 + D70
dazatron
Hello everyone, first post, long time lurker. I'm really interested in his combo but I'm unsure on a few things. I own a Hugo 2 and want to switch to this combo. My first question is which one would be the preamp, secondly I'll be connecting to a naim nap200 so would I connect the dac and hp amp with balanced XLR and the RCA outputs on the dac to the amp, I'm thinking that the dac would be the pre(volume control). Finally how would I switch from listening through speakers to using headphones. Sorry if I'm not making sense.
D
dazatron
Or maybe better off with the dx7pro. Thanks for any help
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Welcome! It's a little early for much of the membership, so you'll likely see some responses soon. ;)
b7676
The headphone amp also has the superior preamp functionality (even ability to add ext90 module).
It has selectable ouputs, you can choose only rca out from an xlr input signal. Or to both. Or rca in xlr out.
The A70 (or the similar L70, A90d) can also select between power and headphone outs active individually or simultaneously.
