On the inclusion of the recording's room effects competing with the listener's room effects:
Your xylophone is an interesting one for several reasons. First, its radiation pattern isn't anything like uniform, and second, the "ring" does not come from exactly from the same place as the "hit", although it's close.
The problem with the room goes to basic psychoacoustics. If you do not have enough information captured in the performance room, your ear can not separate out the xylophone from the room response, and "muddy" is exactly the outcome.
Back at AT&T I had a fantastic way to demonstrate this, and one that also related to .1 subwoofer used for anything beyond "sound effects".
I had a recording of a good pipe organ, in a room on Lake Erie that I can't mention by name, being played by the organ tuner's laptop via midi. (Yes, really.)
I had mono, stereo, and 5-channel recordings, using the PSR mike mentioned above. For the 5 channel, the mike wanted to be back about row 10, so that's where it sat, that being the point of the recording.
Mono was muddier than ()*&(&*(, bass to high frequencies.
Stereo did ok above about 500-1khz, but was muddier than ()*&(*&(. But, above 1 kHz imaging helped separate the reverb from the noise. Below 500 or thereabouts, all was mud.
Five channel +-72, +-144, 0 degrees (not the best, but it was what it was, and yes, it had killer imaging in any direction you chose), hey, no, it's not muddy, you can, now, tell the hall from the recording.
Some interesting points. The 'C' channel was at least 6dB higher in energy than any other channel (yes, it was the one pointed straight-on at the main organ). The L/R/LR/RR had about equal energy. The stereo image was as wide as anyone could want, very much like the hall itself.
The recording was analyzed in more ways than you might want to imagine, and yes, the overall spectrum at the listener was very, very similar in Mono, Stereo, and PSR 5 channel. The perception was nothing like that.
In mono and stereo, the reflection from the balcony was not distinguishable except as a really annoying "blur". In 5 channel, you could localize the echo from the balcony front without any problem.
SO. My point? In order to be able to separate, perceptually, the space from the instrument, you need enough information delivered to the ear to do it.
According to those who want "coherence", so it's clear, there was nothing of the sort going on in the short-term interactions between speakers. In fact, those who are interested in 'absolute accuracy' would have been quite upset with the short-term "interference", but we got the right cues to the ears.
Also, the listening area was much wider. You could stroll around the listening area and get a sense of perspective.
Change of topic--on the notion of a sound field:
I don't know whether this adds to the discussion, but I've said here before that what makes one tuba different from another, if there is a difference that anyone can detect, has more to do with how the sound comes to us in the room than with frequency spectrum as measured up close. We take this as a given with loudspeakers--the sound we hear isn't just the direct sound, but early reflections and room effects also. An instrument that sounds like it's "over there"--like the tall-bell German-style orchestral tubas differs from a tuba that sounds like it's "right here" as with the shorter, fatter American-style orchestral tubas. That has to be an impression based on the sound field--the ratio of direct and reflected sound. The shape of tuba's bell creates this difference, I believe. Try as I might, I've never been able to sustain that effect in a recording, and I believe that is because 1.) I lack the sight, which means the sense of over-there versus right-here is uninformed by knowing where the tuba is, and 2.) microphones aren't placed to capture the same ratios of direct and reflected sound. (Of course, most--but not all!--tuba tone is below 500 Hz.)
But it seems to me that it's not an issue of playback equipment, but rather an issue of--yup--microphone placement and how much room effect is in the recording.
Rick "whose recordings in his living room sound like a performer in his living room when listening on headphones" Denney
Well, yes, radiation pattern of an instrument is a key part of how it sounds. You won't get an argument from me on that. One thing (not aTuba expert here) that may happen is the direction of radiation from the tuba. Tubas DO show a "leading edge" for the upper harmonics, as well as the "pitchy" sound one expects of brass. If that signal goes into the rafters and back down, it's going to sound far away, because those details are missing and you only have HRTF effects to localize it. If that's aimed at the listener, you have additional cues to localize with.
What's more, if you are also capturing the room at the same time, you must capture enough information for the ear/brain to separate out the room from the instrument. If you don't, mud happens.
That was the first result of trying a 5 channel recording with the particular array. First time we did it, we put the array where you'd put a stereo pair. Hmm, yeah, yep, that cornet was RIGHT THERE! And I mean about 2' away from your face. Ditto the Trumpet, Trombone, and everything else. So we backed off to about row 6 or so. Now the 1 and 2 channel recordings were really not good, but the 5 channel recording was quite "present".
Lesson learned right there. The last recordings I made with it, of the old Cantus group in Northfield, MN, we moved out to about row 10. Imaging and sense of focus on performers were just fine in 5 channel. In 2 channel, not so much.[/QUOTE]
