Tannoy Platinum B6 standmount - any info/experience out there
ROOSKIE
Minneapolis
Looking at some options for a new passive stand mount speaker to test.
I am trying to find one from a brand that I have little experience with.
I have never tested/owned a Tannoy product.
I came across the Platinum B6.
I like the look and it is a budget priced set at $280 each/ $560 a pair in the USA.
Unlike most Tannoy, this is not a concentric design. It appears well built and styled. With a small tweeter waveguide.
I can find nothing about this speaker at all, no measurements nor any subjective prose. (which I would take at this point)
This does make it a good candidate to test of course and as well it seems odd how little has been said about it in 2 years.
https://www.tannoy.com/product.html?modelCode=P0E04
**edit**
ended up finding some in room measurements and a subjective review
https://www.hifi-voice.com/testy-a-recenze/reprosoustavy-regalove/2325-tannoy-platinum-b6
Vini darko
Dorset England
Worth considering that if no ones reviewing a product from a major manufacturer in the budget arena. There's likely something wrong with it that's causing reviewers to reject it.
akarma
Freaquency responce is very neutral. Any owners here? How are they comparing with Elac Debut Reference DB62?
Tannoy
Elac
jhaider
If it says Tannoy on it I expect it to have a dual concentric driver.
purplevendetta
I have the bigger, floorstanding Platinum F6. While I'm perfectly happy with them, I would really like some measurements, as a confirmation. Apparently there are none, but the frequency response curve of the Platinum B6 seems promising
Talisman
Milano Italy
I found these speakers at an incredible price, 199 euros, intrigued by the brand and the aesthetics (for me they are wonderful) I compared them with the Kef Q350 that I own and I was very disappointed, the bass is not very high, the treble is a little too bright , generally they sound "smaller" than kef, really a shame
Putter
Albany, NY USA
View attachment 209075View attachment 209076View attachment 209077View attachment 209078View attachment 209079
Of course they have a 'smaller' sound. They look to be about 2/3 the size of the KEF's. Also I suspect that KEF's Uni-Q coaxial design frees up additional space. The frequency response seems reasonable, but the waterfall appears to show significant directivity problems at 1 and 3 Khz and is not particularly smooth. understand this 'review' is somewhat tongue in cheek having never heard either speaker.
