- Thread Starter
- #21
And this relates to capacity. How much capacity is needed, then depends on what we see as meaningful spl, at least it should be audible.
At the listening position, audible means approximately:
90dB at 10Hz
80dB at 20Hz
70dB at 30Hz
Tactile feel - to feel the sound physically on your body - starts at around 80-90dB, but is very dependent on mechanical properties of the floor at very low frequencies. This also depends on the properites of the sound field - the intensity and particle velocity.
Those detection levels will be higher if sound at higher frequencies are present, the higher frequencies will mask the ultra-low frequencies.
For realistic spl levels, it makes sense to dimension for around 110-120dB. Then you will be able to play quite loud, and have a nice physical impact.
A subwoofer is measured at a given distance, in specified surroundings, often 2pi/ground-plane. How loud it is in-room at the listening position depends on placement of subwoofer and listener, room size, and room loss. A small sealed room with rigid walls will be louder that a large, open space. Fortunately, room gain increases with lower frequency, in a sealed room. The bad side is that intensity and particle velocity decreases.
So we see that a subwoofer needs more output at lower frequencies to be usable. Since output from all subwoofers decreases as frequency goes down, we see that is will be the capacity at the lowest frequencies that sets the capacity limit for the system. So to get usable extension well below 20hz in a large room, the subwoofers will need to be quite large.
But for most music, those capacity requirements can be relaxed quite a bit, because music rarely has very loud levels of ultra-low bass, typically max spl will be limited by capacity in the 30hz-and-above range.
Thanks for the detailed answer.
