Stax SR-X9000
jhenderson0107
California
Inspired by Amir's review of the Stax SR-009 headphones, I recently added a SR-X9000 and Mjölnir Carbon CC amp to the headphone station in my den. I haven't owned or worn a pair of electrostatic headphones since 2001 when I sold my SRS4040ii combination. My recollection of the SRS is that it sounded very good - if you sat absolutely motionless. But even the most minute shift in listening orientation would result in creaking plastic, which was exceedingly distracting.
I wanted to see how much things may have improved in Stax-land.
I used the auto eq feature at Squiglink to generate 10-band Kemar DF and Harman 2018 PEQ correction profiles, which were then transferred into rephase, to allow creation of convolution impulse files suitable for Roon and Logitech Squeezecenter. A similar procedure was used to generate convolution files for the Senn HD800s headphones (also depicted). The PEQ feature of the RME ADI-2 DAC fs was disabled, but loudness compensation was enabled.
I typically listen to classical guitar, lute, theorbo and chamber music but I also enjoy jazz and ambient.
I was delighted to discover that the X9000 - similar to the 800s - can be readily corrected to the Harmon 2018 target curve and driven to even uncomfortably-loud listening levels without any discernable audible distortion. The X9000 delivers plenty of clean bass. As to be expected with convolution correction enabled, the sonic profiles of the two headphones are similar. However, their "sound stage"/portrayal differ sufficiently that they can be readily identified.
Of course, I did not strive to perfectly-match their frequency responses. I presume that achieving such a match would require a suitable headphone test rig, much iteration and much more patience than I possess. Consequently, each pair of cans exhibit small post-correction nulls and peaks that may account for the sonic differences.
Both headphones are extremely comfortable. Importantly, due to good material selection and build quality, neither generates spurious mechanical noise whatsoever. Nor can I detect any microphonic cable pickup when shifting position in my listening chair. Both get plenty loud, but I typically listen at relatively low-levels and rely on loudness compensation.
They're huge and overpriced, but still less preposterous than my long-time favorite AKG K1000s. Overall, I like them.
That's a $13K setup (Amp+Headphones), almost 10x the price of the 800S for what reads like an equally comfortable and well built, but slightly different sounding pair :D
That's probably right. And to add insult to injury, the 800s is probably 5x more expensive than a nearly-equivalent sounding open-back headphone with convolution correction!
I purchased the SR X9000 a few weeks ago and I like it a lot. The Stax X9000 is priced like an end-game headphone, and delivers on it. The X9000 combines the big soundstage of the Sennheiser 800 with the purity and non-distortion of electrostats. I liked it without EQ, but proceeded to EQ it directionally toward the Harman 2013 curve using my ADI-2 DAC. My old Topping EHA5 amp sounded fine on music at moderately loud levels, but would temporarily shut off on sub-bass test tones at high volume. I bought the Stax SRM400s and has no issue with heavier sub-bass boost, and will happily drive music to deafening levels without distortion, though I prefer to avoid such levels. With EQ boost, I'd say musical bass is clean and ample, and the soundstage, transparency, and lack of distortion is excellent. I'm a fan of the large earcups and the space it seems to convey, just as I have been with my Senn 800 headphones. They are still headphones, but somehow the stage seems bigger and more real with the X9000 (and HD800). The HD800 sound is just slightly muddier in comparison (something I originally noticed versus the budget Stax SR-X1). I listen to mostly classical music and prog rock.
