It's OFC, though?Of course I have... where'd you get that silly notion from? Technically, that's what is snaking all around my room!
So zipcord cannot be ofc, by definition?It's OFC, though?
I don't think it usually is, that's all. No need for audiophile lamps and stuffSo zipcord cannot be ofc, by definition?
I agree. It's not like larger wire is a major investment.LS50Meta speakers are rated 85 db efficiency at 8 ohms. Inefficient speakers - at least they are 8 ohms which helps a bit.
Don't skimp on wire size.
If it's not clear insulation then how do you know if it's oxidizing inside or not? FWIW no problems with the last two 300 ft reels of Monoprice 12g but then again oxidization is more an aesthetic thing.I have had Monoprice OFC cable oxidize pretty badly after just 1 year.
This is may or may not have anything to do with the brand, rather I suspect any brand can have a bad batch or even just a bad product.
May be a reason for clear jackets - to see what is happening inside the with the wire. Yearly inspections anyone
That said my cable of choice right now is a non-clear jacket.
I just buy this brand in various sizes.
Extremely flexible and easy to handle and a high strand count which I like. It feels premium vs other similar rip chord style spools.
KnuKonceptz Kord Kable 12 Gauge Copper Speaker Wire
I may try this brand next
InstallGear 12 Gauge Speaker Wire (100ft) - Brown 12 AWG
I've been using this as well for years with no issues.I have used this with total satisfaction for over 15 years and four upgrades in speakers. I don't even use banana plugs because I rarely make speaker changes. I have a 50-foot run to the farthest speaker, so I bought 100 feet. You should get along with a 50' spool. In my case, I'm connecting a 150-watt per channel amp and a speaker set measured at 5.0 ohms minimum. Works fine.
Audio techs I know working in recording studios and similarly powered reinforcement only choose heavier-duty/heavier jacketed cables for durability and flexibility, not audio quality. For more than a 50' run, I might change to maybe some 10 AWG wires.
If I wanted to make a better investment, I'd take the price of foo-foo cables, subtract the $30, buy these, and use the difference for lottery tickets. You're more likely to win for the price.
The old lamp cord was OFC in vinyl, pvc, cloth and just about everything else. Oxygen Free Copper isn't anything new. Aluminum and aluminum with clad copper is.I don't think it usually is, that's all. No need for audiophile lamps and stuff
Hmmm, thought the typical lamp cord was just ETP. Why would it (CCA) roll off frequencies if of sufficient gauge?The old lamp cord was OFC in vinyl, pvc, cloth and just about everything else. Oxygen Free Copper isn't anything new. Aluminum and aluminum with clad copper is.
It rolls off the upper frequencies. It will never sound bad. On the other hand it will NEVER sound good either.
I'll say it this way, great cables never sound bad, I've never notice great cables. Bad cable on the other hand, everyone is scratching their heads and asking if you have
any whisky and I can see TP in their ears.
Regards
Didn't know there was a Monoprice UK, good to know. They carry the Monolith lines too?Just picked up 60 metres of 12awg from monoprice UK for £50.
Thanks everyone, for the advice & info
Really, audio frequencies? If so, would be trivial to measure. Can you point me to the data? The types of effects (that I know of) that would cause this are typically really high frequency, like GHz or THz.Aluminum and aluminum with clad copper is.
Aluminum wire was first used in the 19th century. It was used for domestic wiring 60 years ago. There is no such thing as oxygen-free copper wire - oxygen is injected into the molten mix to burn impurities, and some of it stays - but the current mania for reducing oxygen content to a minimum is relatively recent, for certain very technical applications. To have transferred such worries to audio is ludicrous - no possible amount of oxygen has the slightest effect at low voltages and audio frequencies.Oxygen Free Copper isn't anything new. Aluminum and aluminum with clad copper is.
This is wrong too.Aluminum and aluminum with clad copper ... rolls off the upper frequencies.
Whew! I was worried for a second that clouds of ionized plasma would form every time I brushed up against anything, and other stuff. Good to know I can start moving around again without dramatic sponteaneous electrical phenomena randomly occurring.This is wrong too.
Hi Chrispy,Didn't know there was a Monoprice UK, good to know. They carry the Monolith lines too?
So in the UK a purchase now with Brexit adds some hassle/expense I assume?Hi Chrispy,
Yeah, I believe they do carry the Monolith stuff, from my confirmation email, it looks like it ships from Germany, which makes sense as Germany is central to the whole of Europe.
