WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
What USB-C > 3.5mm do you use with your Pixel on the go? I just got the Pixel 8 and am now a headphone orphan. Unless I keep the 4a 5G around just for music. Which I might do.
I have two dongle DAC/amps (Tanchjim and the Qudelix) that I connect with USB, then connect headphones to the DAC. I do miss the headphone jack on my old LG.
My S10+ has a HP output jack and sounds good but limited in volume. I don't think Samsung includes 3.5 mm outs on any of their flagship phones anymore.
Yes, 10 was the last from "S" line. The highest we can go with 2023 line for instance is M34/F34 (siblings models), lower tier, but not that bad specs for a music player - 5G 6,5" FHD+ Amoled, microSDXC, Li-Po 6000 mAh etc.
I wonder how you'll insert USB-C cable directly into 3.5 mm jack? AFAIK you'll need an USB-C to 3.5 mm adapter cable - which will have its own DAC inside.
Unless one uses something like UAPP which can bypass the android mixer, hence the internal phone DAC then one will "hear" the internal DAC even when outputting from the USB C jack to another outboard dongle DAC. Maybe that's clearer.
Thanks for clarifying that. Those tiny electrons in smartphones bamboozle me. So the only drawback to not using UAPP is the sampling rate being fixed? Is the stream bit perfect in this configuration?
Definitely not for anything that is not 48 kHz, it’s resampled after all. At 48 kHz, still not sure. It may even differ from phone to phone, depending on how it is implemented.
I guess my confusion is how does that sample rate conversion occur? What device converts this? I thought it must be the DAC, as most can perform sample rate conversion (can't they?).
I guess it could be done in software? Clearly I'm making too many uneducated assumptions without the requisite knowledge of how smartphone/Android mixers work.
