Similar sensitivity, Way different perceived loudness?
frimincoffee
Hello.
I did some trial and error to match loudness of headphone with Peace(Equalizer APO) preamp
by
1. Using can's sensitivity(db/1Vrms) spectification and headphone power calculator.
2. Preamp to match my SPL target
3. Adjust non-preamp-ed volume to match my SPL target
It is not accurate, but I'm pretty satisfied what I did.
But when I try the same thing with IEM that I did with headphone,
its sound way louder so I had to adjust preamp setting by add -6db.
I know my dac/amp do not have some kind of high/low gain caused by impedance of can.
It really not a problem but this experience got me thinking
: With my short-knowledge speculation, the 'sensitivity' means how much SPL driver can make with 1 Volt.
Then what I should do with the differences of headphone and IEM to get similar loudness level I perceive?
Is this all about how driver close to eardrum?
staticV3
F
frimincoffee
So my thought about sensitivity was wrong!
Then why I had such a noticable difference? Because the manufacturer are different?
By the way I did some test with Sennheiser HD560s(110db/V) and 7hz Salnote Zero(108db/V)
edit : I'm terribly sorry, my dac/amp has some of output power change when impedance is different.
DVDdoug
If the measurements are done on the same set-up they should be comparable. Measuring SPL output from a headphone isn't as straightforward or reliable as something like a voltage measurement so I'd expect some differences with different manufacturers. Even the same manufacturer might use a different setup with headphones & IEMs.
And sensitivity is usually measured at 1kHz so frequency response differences can make a difference with music or other program material.
I know my dac/amp do not have some kind of high/low gain caused by impedence of can.
It's possible for a low impedance load to "drag down" the voltage making it lower than "expected". But usually it's the IEMs that are lower impedance so they would be quieter than expected.
F
frimincoffee
Thanks. In this case IEM was louder, guess it is a measurement difference and I have to adjust by my ear.
