Seek advice: Front tower speaker recommendation budget USD 1600 max
Hi everyone,
I'd like to get your recommendations between Kef Q11 Meta, the Polk R700 and the Revel F35. I'm able to get the Revels from Crutchfield at 449, Q7's locally at 800 each and R700s at a similar price too. My setup is a Integra DRX3.4 with a Buckeye NC502 6 channel. My center is a THX-365C and I have the Klipsch Rp-600M IIs. I don't have a dedicated HT room. It's an open area on adjoining a stairs and a balcony that overlooks my door. Layout is included. I know it's not ideal but at least it's carpeted with 9ft ceiling. No room treatments possible. Can I please have your informed opinions.
Thanks!
Try to find F36 now on clearance sale if you can. They are nice just don't play very nice with ceiling refractions.
Based on this, Q11 wins, R700 2nd, F35 worst.
Thank you digitalfrost! One question though, based on directivity, shouldn't the F35 be better than the Polk R700? Also the F35 seems to have a better horizontal dispersion compared to the rest. Am I reading the graphs correctly? Can you please explain?
Thank you Zolalll. What would be the benefit of F36 vs F35? Can you please explain?
3x1.25" bigger woofers (3x6.5 vs 3x5.25) same with better peek handling regarding extension. Simply they are now on clearance sale (discontinued) so you probably can catch them for a price of R700 Elac's and similar.
I was just going by the preference score. Q11 is best followed by R700. The Q11s have narrow dispersion if you like wider the R700 might be the better choice, and while the F35 indeed have nice off axis response their tonality score is worst of all 3. These are all good speakers nonethenless. It seems the Polk go significantly deeper than the others though.
Agreed on the Revel F36's if you can find a pair. As I understand it, your Integra DRX-3.4 AVR comes with Dirac Live. Your three choices are good loudspeakers and Dirac Live can mitigate their deviations from 'perfection'. Consider the Revel F35 if you have a preferred use for the $ savings. Consider the Polk R700 or KEF Q11 Meta if you might wonder what you are 'missing' by not spending more. I perceive more distinct imaging from the Uni-Q driver in my pair of LS50 Meta loudspeakers. The Polk R700 will likely go the lowest of the three. I use a pair of Polk ES60 loudspeakers in a 2.0 configuration and am satisfied with the low end extension.
Thank you all for kindly replying to my questions. I do prefer better dispersion as my seating positions are far from ideal. Given that I'll be getting a sub soon, I will be going with the F35s that I'm getting for about 800. I tried finding the F36s online but couldn't. Given the PS is marginal with 0.5 difference in the scores and that the room is rather small, I think I'll be happy spending less on the Revels. I appreciate your help, @digitalfrost @ZolaIII @Power Pop 23
Just 'cuz I'm biased at the moment towards Revel I thought I would point out that if you compare the on axis data on spinorama the F35 and Polk appear equal and the Kef is the worst, but then add in the huge price differential of $449 for the Revel vs. $1099 for the Polk and $1249 for the Kef and I would think the F35 wins hands down.
What I see as a real shame is that the Revel Concerta line is discontinued so once the current supply of F35s is gone I don't know of any other tower speaker at that price range with that kind of data. Too bad.
I feel like we just had this same question a couple weeks ago? I'll put in the obligatory mention of the new-ish ELAC Debut 3.0 DF63 for $1100 a pair that measured fairly well with Erin's Audio. Not as nice as the Revel's but ok and cheaper.
Just curious, but where do you see the Elacs for $1100 a pair? The cheapest I found online was $1300 a pair.
Also, I've seen several posts regarding the Elacs and watched Erin's review and they do look nice, but just want to be clear the Revel F35s are on sale for $890 a pair :)
oops, i thought I saw they were 1100. Either the price hikes from tariffs have hit or I just misread. TBH, I was thinking of the F36 since it has the larger bass drivers, but I suppose the F35 is (or would have been if not discontinued) the real competition to the Elac.
Hi everyone,
Thanks!
I recently got a set of KEF Q11 Meta for use in our fairly "dead" family room and have been listening to them for three or four weeks now. I'm not a measurements guy, but I can tell you the highest frequencies seem to be pretty tame. Unless I'm right on axis, I don't hear them too much. However, this perception may be significantly due to my high frequency hearing loss.
Hoping to piggyback on this instead of making a new post but I picked up a pair of the F35's seeing they are in my budget and am looking for a center now.
Looking at the Monolith 365c,Paradigm Premier 500C/600c,even found a used Revel C208 near me but that is way too big for my room I imagine(16' x 11') and would overpower the F35's. Would the Paradigms be a good match? Open to other suggestion new or used under $1k
Hi everyone,
Thanks!
I would suggest buying the
Revel F206 $1295​
They will work great with e 365C. It's a great price and they will surpass the other choices you have listed.
Revel F206 $1295​
+1
I paid $1,800 USD for a pair 5+ years ago and they were a great value at the higher price I paid at the time.
