terryforsythe
I have seen something like this a few times, not sure if it's the same problem or not. In my case Windows doesn't manage to start playback to the usb gadget. Rebooting the pi solves it. I haven't updated anything on that system for some time so it can't be caused by some recent update. Of course it only happens just when I want to listen to something, so I haven't investigated yet.
Thank you for the input! This morning it is working fine. I checked my logs and the apt-daily-upgrade.service seems to have run overnight. I also forgot to mention that I have Timeshift that runs automatically, but it also ran overnight. Nonetheless, this morning I had no issues.
I'm still having an intermittent issue with CamillaDSP going off line, and needing to reboot my Pi. I'm digging through my log file to try find the cause. The other warning I had I fixed by increasing the buffer size for camilladsp-setrate.
EDIT: Digging around I noticed I forgot to set my location when I setup Raspberry Pi OS Lite. It defaulted to the UK, but I am in the US. I just changed it. I doubt that was the cause of the issue. I'll see if it happens again.
EDIT 2: I just created a script file to restart both CamillaDSP and camilladsp-setrate. I will give that a try next time it happens to see if that works to avoid having to reboot.
Another weird issue I noticed today: If I use "sudo reboot now" the WiFi does not come back up on reboot. If I use "sudo shutdown -r now" it seems to work perfectly fine.
