Killingbeans
So.... that's a 'no'?
Here where I am take a measurment mic and calculate the acoustics of the room is difficult .So.... that's a 'no'?
Like I said above, in-room measurements might not be the best tool for the job. I'm a novice in that area myself. But if something is going on that actually makes vocals "inaudable" in some cases (as you say), it should be rather pronounced in one kind of measurement or another.
My main point: Investigate some more before you try to fix anything.
There really shouldn't be any audible difference between those two DACs.
lost foreverIt says in this implementations some midrange will be lost forever
hahah i don't get your reaction ...xaxalost forever
i found this reviewer that says what i am discribing about the topping d50s dac
If some midrange is "lost" surely it would be lost across all forms of music.In the other hand jazz music songs with vocals and pop songs are 100% legit and great sounding .
Maybe the dac magic 100 was colouring the sound so I liked it more ...
The Dac Magic measures fairly well, so it's unlikely to have coloured the sound.If the problem was speakers ..why dac magic 100 was sounding ok . Maybe the dac magic 100 was colouring the sound so I liked it more ...
What about my Denon 520ae amplifier ??Another possibility: The Cambridge DAC has a higher output voltage. Differences in volume can easily screw with your head.
Would you recommend any amplifier to upgrade to ?
I asked if the amplifier would improve the sound generally. Also if my amplifier is a good one from your expirience .I don't follow What about it?
No. I don't see what your amp has do with any of this.
All I tried to say in the previous post was that if you listen to the two DACs volume matched, there's a good chance the differences will disappear.
I really wouldn't worry about the DAC. If you don't like it then return it. Accurate testing would not only require level matching, but also double-blind testing.I asked if the amplifier would improve the sound generally. Also if my amplifier is a good one from your expirience .
Nothing to do with the dac.
As for the dac i will try to play them volume mached . I don't know how to achieve volume match if d50s dac at 0db has less output that the dac magic 100 . Maybe adjusting the amplifier , but is this accurate ?
