Recommendations for DAC under 50$ to eliminate static noise on PC (headphones use only)
DrLastContaQt
Poland
Hi, Im bedroom DJ at night and marketing specialist at daytime :D My interest in music stared 24 year ago. Couple days ago I change CPU fan in my PC and from this moment I hear static noise when moving my mouse. I read a lot about it and there is nothing I can do for improve grounding. Im using motherbord build in Realtek sound card. Mamy people suggested, that buying external USB sound card should end my problem. But... because Im a perfectionist I stared to some research and stumble up this forum. I think you can help me decided what to buy. I use my PC for work and prep for my DJ sets. Im constantly listen to music, to find new tunes and inpire myself. Im susing gaming HyperX Cloud headset (60 Ohm) and Sennheiser HD 25 (70 Ohm). I need DAC or new sound card or USB dongle, whatever to drive my headphones and get rid of static noise. I don't won't to spend tone of money on it. My budget is 50$ max. Any recomendations?
AdamG
Moderator
Reality
Welcome Aboard @DrLastContaQt.
Vict0r
The Netherlands
Vict0r
The Netherlands
Thanks for recommendation. I read, that this DAC is not recommended for headphones with impedance higher that 32 Ohms. Im using 60 and 70 Ohms headphones.
Only if you need ear-splitting volume. :)
DrLastContaQt
DrLastContaQt
Poland
I don't need that. I'm always take good care of my ears. On 60 Ohms headphones connected to build in sound card I'm using only 16-20 % of max volume :) Higher is too loud for me.
DrLastContaQt
DrLastContaQt
Poland
What about Meizu HiFi standard (non PRO). It costs about 20-25$ on Aliexpress at the moment?
EDIT. Never mind. I found review here for this product... PRO version looks better but is unavailable ATM.
mkawa
meizu pros are out of production. however, they are straightforward cs4313 implementations, as are the sonata hd pro
DrLastContaQt
DrLastContaQt
Poland
Try optimize your pc first for audio first
All settings mentioned in this video are settings useful if you are recording music into you PC, so you PC will use max CPU, never switch off monitor, HDD ect. There are not relevant to listening to music. But thanks for posting this video.
sumpao
It does effect playback music.
If you follow the step you will not get system sound it huge different
other than that after i set up like that i never got strange sound from pc again
DrLastContaQt
DrLastContaQt
Poland
Define "strange sound"? Problems with PC audio (static noise, clicking ect.) are caused by cables and electricity interference inside PC (fans, graphic card, SSD cables ect), so any software settings usually can't solve it. That is why I bought external DAC, to move DAC out of my PC case.
sumpao
1. Pop sound when change application Jriver>Netflix
2. Pop sound when notification appear
and etc
sumpao
I use external dac and that problem don't go out 100% when you change to external dac.
Window setting is also a must for playback
