- Joined
- Aug 3, 2019
- Messages
- 929
- Likes
- 1,424
I power my TPA3255 chip amps with a typical Mean Well clone SMPS that has an always-on two-wire cooling fan. In an effort to limit its cooling fan noise, I bought a supposedly quiet Vantec PC case fan that was too thick to mount inside the case, so I mounted it outside, and the resulting setup is just as loud as the original inside-mounted fan. Since current demand from the amps is relatively sporadic with occasional peaks and the SMPS runs pretty much ice-cold, I'm wondering if it's a sensible risk to run it without a fan, perhaps slow the fan down with a simple series resistor, or even concoct some sort of physical muffler arrangement. Any and all idea appreciated in advance!
