Hello,
I have recently built a Hypex based system with DLCP (a DSP) in 1 metal chassis and the Hypex UCD amps (and their power supplies) in another chassis.
I wanted to know - what is the technically correct way to handle pin 1 in a multi component build?
I have followed the wiring guidelines from Hypex, and from Bruno's paper on pin-1.
In pre-amp:
* Each signal cable from dsp board has a shield, which is connected to pin 1 of XLR-out on one end, and the shield pin on the DLCP-channel-out on the other end.
* pin-1 of XLR-out is connected to chassis also.
The above connections are made for all 6 channels in the pre-amp chassis.
In amp:
* Each signal cable from XLR-in to amp has a shield, which is connected to pin 1 of XLR-in on one end, and the shield-pin of the amp's audio-in on the other end.
* pin-1 of XLR-in is connected to chassis also.
The above connections are made for all 6 channels inside the amp chassis.
I would like to double check if this is the correct way to connect components.
Q1: It is not clear to me if I need to do this for all 6 channels or only 1.
Q2: In the amp, 4 of the amps are powered by 1 common SMPS power supply, while each of the other two have their own power supplies. I read somewhere that when 1 power supply is feeding more than 1 amp, the signal-shield needs to be connected to only 1 amp. Is there any science to this?
Thanks.
PS: I don't understand electronics, I just wanted to build a system so that I can hear great music.
In pre-amp:
In amp:
Thanks.
