open source DSP?
TriN
Hi!
I'm looking for an open source project, basically a piece of code that gets audio from an input/microphone, does something with it (not important), and output it to the main or selected device
iMickey503
United States PDX
A channel that will help you on your design goals.
Since your looking just for the code? These are you top picks as you can modify them as you wish.
T
TriN
It looks like JUCE is the goto solution for anything audio / cross platform
somebodyelse
There's a ton of stuff on the linux side. PulseEffects/EasyEffects is an easy way to start on the desktop, but there are an assortment of ways to apply effects from LADSPA or VST through ALSA, JACK, PulseAudio or PipeWire.
