New Topping PA3s offering on the corner?
Drengur
Looking forward to tests. I messaged Shenzen moments ago, I will probably not be able to wait until the testing is done. The only problem is I have too many Topping products.
V.b.
Now we need a 130$ dual Merus power amplifier, no volume control.
Vladetz
Russia
Going almost to 97 db sinad, very impressive
Xulonn
Boquete, Chiriqui, Panama
Are these the correct cables for connection an XLR balanced pre-out to the PA3s and similar amps with TRS balanced input? Or is there a different wiring scheme for TRS balanced vs TRS stereo connections/cables?
Walter
If the performance is on par--and I expect it will be--this blows away the $220 Sabaj A20a for value, and the combo with the D10S Balanced will cost roughly the same as the SMSL AO200 while probably providing better measured, though maybe not audible, performance. However, it does have an external power supply, while I believe the other two have internal.
PA3s also does not appear to have a remote. I am very desktop focused these days so had not even noticed.
daniboun
France (Lyon)
Interesting. The Sabaj A20a is not a power brick amp... It has an internal Morsun 350W PFC PSU.
It would have been cool to have the same concept here arf....
Walter
A20a, you mean? Just guessing, but it was probably much less expensive to repurpose the existing tooling for the old PA3. And also faster to market and a smaller case. One of the tradeoffs for the $70 cost savings.
gasolin75
Denmark
No more power then the original PA3
daniboun
France (Lyon)
The Sabaj A20A (my bad) is about $230
The Topping PA3S is about $175
The Sabaj A20A has good Internal PFC PSU @ 350W (LOF350-20B24 ) and XLR inputs and Sub out + remote control
The Topping is a power brick amp (26VDC probably 6A or 7A about 180W ) with less common TRS balanced inputs
Most balanced dacs are equipped with XLR, so you will need a good TRS > XLR cables.
I imagine there is something for every taste and every wallet.
As for the measurements, we will know more soon I hope)
daniboun
France (Lyon)
If you want to know more about the SABAJ A20A, I dismantled it entirely here :
gasolin75
Denmark
cutting it pretty close, the pa3s is nowhere near 200 watt
