new Topping L50 problem
variv
Reykjavik, Iceland
Hi guys,
I just received Topping L50 amp from shenzenaudiostore. I have strange problem with it. I use Chord mojo 2 with 2v output set as a dac, connected by jack-rca. Headphones are connected to L50 via big jack adapter to small jack. In low gain mode I can hear both channels, but in medium and high gain only left channel gets louder. (volume dial is above 10 o clock) When I connect headphones (DCA Aeon X) directly to mojo 2 it sounds fine. Does anyone had similar experience ? Im wondering whats happening.
variv
variv
Reykjavik, Iceland
Thank you for your reply, I tried again after work and the problem disappeared. I'm not sure what happened. Maybe cable/connector problem I cannot replicate.
