Arrives in Europe next week or the week after:
If the company information is correct - and SMSL uses the same analyzer as Amir,
then this is the best DAC in the world at the moment - with a razor-thin lead (you must scroll down for the analyzer graph):
https://www.smsl-audio.com/portal/product/detail/id/847.html
However, they measured it at 5 volts, while Amir defaults to 4.00 volts on the balanced outputs (and 2 volts on the RCA outputs [so costing about 2 dB versus 4 volts]). That might also explain the close new world record of the new SMSL.
I think these things are also getting better because the Chinooks have now mastered even the 7 nanometer manufacturing method for the chips. Less waste heat, less noise, less distortion than before.
It will certainly be put under the microscope by Amir in October or so.
The thing costs EUR 649,-- (and thus even EUR 250,-- cheaper than the D 400 EX with ES9039MSPro chip):
www.audiophonics.fr
I think it's gorgeous. Since the outer skin has those beautiful 50's ripples....
Like a pagoda roof.
Must be solid aluminum........
SMSL D400PRO DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Silver - Audiophonics
SMSL presents with its D400Pro a DAC as versatile as it is powerful, benefiting from rigorous design and top-quality components. It is based on two AKM digital/analog conversion chips: an AK4191 and an AK4499EX.
Like a pagoda roof.
