Florianro
Hello,
I've got a small Project MAIA right now with a Project CD Player connected and an old dual turntable. I use self-made hifi speakers that I really like with that setup.
I'd like to replace the MAIA integrated amplifier and use the SMSL SU-9N to connect with LDAC from the mobile phone. As an AMP I'm thinking about the Audiophonics MPA-S125NC. But I don't know yet how to connect the CD player and turntable. Additionally I think some kind of EQ/DSP and measurementsetup would be good to calibrate the linearity of the loudspeakers.
So some questions:
- What setups do you use to connect the turntable and the CD player to the amp?
- I suppose I'd have to replace the CD Player since it has no toslink output with one with toslink in order to be able to connect to the DAC. How complicated is it to connect a CD player to the SMSL SU-9N (lets say toslink) and select it as imput source? Does it recognize automatically? How would it work to change from CD for example to the mobile phone via LDAC?
- How would you connect the turntable to the Audiophonics MPA-S125NC? Or would you recommend a different AMP?
- My wife wants a setup that's as simple as possible. Would/can you recommend something else that's simpler to use in the same quality?
thanks,
Florian
So some questions:
thanks,
Florian
