Could you zoom way in on that, someplace up high, just to see?
No, I don't disagree with that.I hope you don't disagree that in a non-linear system superposition does not apply.
Well if you are creating these multi-tones because people like to think it is more like music, how about having the level go down as the tone goes up. Something like a pink noise shape. Subtract out the tones and compare with what is left. Multi-tone music test.
That make sense to me. Music is likely to have frequencies 100 Hz and lower near full scale, yet never will have frequencies above 4 kHz near full scale. Well, "never" if it is produced from acoustic instruments. With a 2-tone test 19 + 20 kHz, a CD player I used to own (Rotel RCD-1070) measured 30 dB lower distortion when I reduced the test signal from 0 dB to -1 dB. So the frequency vs. amplitude of the test signal definitely changes the distortion profile.Well if you are creating these multi-tones because people like to think it is more like music, how about having the level go down as the tone goes up. Something like a pink noise shape. Subtract out the tones and compare with what is left. Multi-tone music test.
It's also quite common if someone is using multitone. A issue is that low frequencies likes to take up headroom so the resolution can be an issue. As low frequency goes higher the different types of distortion is more likely to show. The averaged energy spectrum of music does not represent where the distortion generated. Music is still more dynamic than multitone. It's most likely the transient that causes distortion which is higher frequencies.Well if you are creating these multi-tones because people like to think it is more like music, how about having the level go down as the tone goes up. Something like a pink noise shape. Subtract out the tones and compare with what is left. Multi-tone music test.
That is why I like the twin tone IMD signal. Has steep transients naturally.It's also quite common if someone is using multitone. A issue is that low frequencies likes to take up headroom so the resolution can be an issue. As low frequency goes higher the different types of distortion is more likely to show. The averaged energy spectrum of music does not represent where the distortion generated. Music is still more dynamic than multitone. It's most likely the transient that causes distortion which is higher frequencies.
So we cannot have a single measurement that tell us all. We still need different types of measurements to fully utilize the test equipment and to fully test out a device.
Nothing wrong with that.That is why I like the twin tone IMD signal. Has steep transients naturally.
I'm in full agreement we need multiple test signals to know a device's capabilities. I don't see big advantages of multi-tone over two tone however. I also think twin tone tells us more than a single tone.
The other gorilla in the room is group delay, in that the phase change of the lows and highs as they pass through the DUT.
The other gorilla in the room is group delay, in that the phase change of the lows and highs as they pass through the DUT. Advancing or retarding the bass can make a big change in overall character of the reproduced audio, harder or warmer sound overall. Just sayin that these days our typical analog chain gear has distortion and noise area well under control.
The first thing I would try is multi-tones at constant rms level but varying crest factor, and constant crest factor at varying rms level. The problem one runs into is that while these things seem like interesting ideas there is not much around on interpreting the results.
Is group delay audible in the lower frequencies only? Here's the phase difference plot for that same multi-tone test I posted for Apogee Element. It doesn't appear huge. Is this audible and/or significant?
Is that a comparison of input and output to your amp and are you confident of the accuracy, do you have a scope or other device to correlate phase shift input vs output, same volts in and same volts out? Would you consider trying at other frequencies up the line to 20Khz please with some other method? This would not be the same in the SET amp world vs solid state.
This 1ms at this frequency is for sure not of any concern imo.
