wargreymon
- Joined
- Apr 25, 2020
- Messages
- 14
- Likes
- 6
I currently have a pair of Audioengine HD6 but the DAC in it seem to be failing with left speaker being louder to the right one. This had been happening for the 2nd time where the last RMA took me for 3 months.
So, I am thinking that it is time for me to go for an upgrade instead of sending for RMA for another 3 months. I had come down to the 3 choices below and have a hard time making a decision
Currently built-in DAC: Audioengine D1 via optical input, AKM4396
Upgrade option:
1. Schiit Modi 3 - Seem to be a reputable brand amongst reviewer, AKM4490
2. JDS EL DAC II - Most of the reviewer are paring it with EL Amp II for aesthetic, AKM4493
3. SMSL M300 Mkii - On paper, it seems to be much better than above 2 DAC but some review said the sound signature to be less fuller and hold back at the bottom and top when compared to Modi 3. It also used a better flagship chip than above, AKM4497.
Optional: Was also looking at SMSL M500 using ESS9038pro chip with MQA decoding. But it seems to be a little more feature than I need.
Please anyone could help suggest what I should get? I mostly use optical input and for now, will be using the amp built-in Audioengine HD6. Budget between 100-300USD to start.
Thanks!
Upgrade option:
Thanks!
