I remember a post, I think by Amir, that if the preceding device has at least 10dB SINAD advantage, it will not negatively impact the performance of the device in question. For example, if the DAC has 10dB higher SINAD than the pre-amplifier, which in turn has a 10dB higher SINAD than the power amplifier which has a 10dB higher SINAD than the loudspeaker, the determining factor, in terms of fidelity/SINAD, is the loudspeaker. Of course, speakers have many other criteria for evaluating their performance. The question is, if the 10dB rule is applied to the signal chain, can one rest easy until the loudspeaker distortions are sufficiently reduced. How does one measure the most relevant metric (at the speaker level) to apply in this scenario? THD? IMD?...
Following this thinking, and building speakers myself, I have concluded that Hypex plate amps provide all the fidelity I will need for a long time to come, even if my current speakers opperate at less than 0.1% THD from 160-10kHz at a reasonably loud listening level (>90dB @ 1m). Am I wrong? How can I meaningfully improve on the Hypex plate amps? Thanks!
