My experience: I spent the golden era of vinyl as a DJ, so I'm familiar with direct drives and I still have my 3 Technics SL1210s from the time (the one and only TT for DJ's). Another vintage TT that did really well was the Technics SP15: a monster of power. In the 70s/80s there were also Thorens and Pioneer: their excellent high-end products of the time are still doing well today. note a detail: in those days the base of the unit was made of wood (classy!)
Unfortunately this vinyl trend has skyrocketed the prices of fully serviced vintage. If you're trying to keep your budget low, the only deals you can still find are broken units to fix (skills required)
Thank you again.
I went deeper into searches.
About turntables of nowadays, there is this video to see inside the Audio Technica AT-LP120 :
God, so much plastic ! I will pass now for sure...
When you wrote "turntable from the eighties" I thought again about Technics that was recommended before in this thread, SL-Q2 and SL-D2 models, direct-drive, quart and servo controlled, plastic-alu alloy chassis.
I grew up with a Technics TT, an entry-level plastic chassis / semi-auto / belt drive SL-220 but it simply looks like Technics was a big name in the 70s and 80s.
This page has a lot of info
https://vintagetechnics.audio/turntables.php
I prefer on paper the SL-Q2 because quartz.
Then I took a look on what I can find near home and I found a SL1800 MKI for about 100 €.
So a direct-drive one, servo controlled (MKii is quartz) fully manual.
I read it is the same motor as the SL1200, I am not sure about that.
What I like is the simplicity of a manual turntable.
SL1800 MK1 inside :
A motor, a tonearm, that's it.
SL-Q2 looks solid too :
but semi-automatic means a bit more parts and some plastic ones :
I guess both SL1800 and SLQ2 have this plastic/aluminum alloy chassis from Technics.
I didn't plan to buy the turntable until several months but I guess I will go for the SL1800 near home, like 130€ with road trip.
SLQ2 goes for 200€ and more in Europe without shipping.
Quieter but out of speed
Choose your poison.
I guess in front of the speakers speed variations are easier to spot than noise problem...
I am not fond of the used Thorens I can afford, e.g. TD166 : AC motor (noisy I found), plastic pulley easily out of roundness, resistors on motor heating a lot etc.
I took a look on Pioneer models I can afford, nothing great beside the Technics I quoted above
