pseudoid
Would you please care to explain -- in detail -- BOTH these assertions?Windows is inferior to almost any streaming device for these purposes.
Big, broad brush [<< imo]
You tell me you disagree but you don't explain why and then you go on to speak about price, which, for the level of expense, might not be a concern for everybody.I disagree, but even with your statement, that requires a serious PC (>$2,500). And unless you have a large projection screen, I doubt madVR really does a visually better job of upscaling 1080p than an NVidia Shield on a normal-sized display. And then you have to get signal from the large noisy PC to your AVR/processor.
If you can control fan speed (with software), then most reasonable (power efficient CPU) fans can be made quieter than average background noise for 85% of usage. Typical fan curves are rather too aggressive/fast for my tastes.If we go to NUC territory, you can absolutely passively cool a NUC. More money, sure, but then it's totally quiet, zero fans used (unlike Shield which has a fan, but I don't think it uses it when doing multimedia jobs, just for gaming most likely).
I mean, really? Have you personally tried to stream 4k HDR from a Windows OS computer? Have you done so with a streaming device? Ignoring the fact that Windows is still terrible at HDR and can't do Dolby Vision at all...Would you please care to explain -- in detail -- BOTH these assertions?
I mean Really? x2I mean, really? Have you personally (1)tried to stream (2)4k HDR from a (3)Windows OS computer? Have you done so with a (4)streaming device? Ignoring the fact that Windows is (5)still terrible at HDR and can't do Dolby Vision at all...
The OP is asking for a pre-built machine with functionality at least matching streaming boxes. They don't sound like the sort to spend a lot of time and $2,500+ to run madVR. Can you run madVR with streaming services?You tell me you disagree but you don't explain why and then you go on to speak about price, which, for the level of expense, might not be a concern for everybody.
As far as upscaling is concerned, there's plenty of in-depth research available online. No solution among the best available is viable on Nvidia Shield. Even its AI upscaler has been surpassed by the PC version. Nvidia's words, not mine: https://blogs.nvidia.com/blog/2023/02/28/rtx-video-super-resolution/
I have done comparisons on my 77" screen and yes, I do notice the difference between the scalers available on a Shield and what I can do from a PC. As far as noise is concerned, there are options to mitigate that. In my specific case my PC is inaudible during daytime but it can be heard, faintly, at night. Not while enjoying content, though, apart from really, really quiet moments.
You still can't do Dolby Vision...and what is the ergonomic situation of selecting a show and getting it to your display? Ever have Windows notifications for updates and other items annoying your process? You aren't really being honest in saying that there are no greater hassles running a HTPC for video playback than a streaming device.I mean Really? x2
If Netflix/AmazonPrime or pushing 4K video over a local network'd NAS may fit your description of "streaming", then my answers are the following:
(1) Yes
(2) Yes
(3) Yes
(4) Yes
(5) Yes
Has your questions to my question - and my answers to yours -- answered my original question?
Both. I see a difference in 1080p too, which I suppose was what you were interested in.you see a difference between the Shield and madVR on your 77" display, but can I ask what material are you talking about? 480p or 1080p?
Do you route HTPC thru an AV receiver/Pre or direct from HTPC' HDMI to TV? And then e/ARC?Personally I am too used to the absolute flexibility granted by a HTPC to give that up.
Try Kodi DS-player. not just Kodi.Do you route HTPC thru an AV receiver/Pre or direct from HTPC' HDMI to TV? And then e/ARC?
What app do you use to play videos on your HTPC?
I have been using ZoomPlayerMax for about 4 years, along with a wireless mouse as remote control for my NUC10.
I connect my RTX 3070 to my AVR and that to my TV.Do you route HTPC thru an AV receiver/Pre or direct from HTPC' HDMI to TV? And then e/ARC?
The 3070 ?I connect my RTX 3070 to my AVR and that to my TV.
I use Kodi DSPlayer, already described above this post.
Zoom Player was what I used when I first built a HTPC in 2007. Back then there was no Kodi for Windows, let alone the DSPlayer fork.
In the earlier days of 1080p video watching - before HTPCs - I was using the Patriot BoxOffice PBO/Core, and then PBO/Alpine boxes!Zoom Player was what I used when I first built a HTPC in 2007. Back then there was no Kodi for Windows, let alone the DSPlayer fork.
Don't the most current "4K" TVs already do the upscaling to their native 4K panel default?The 3070 ?
That's an overkill.
Mine has an RX 570, and madvr has no problem upscaling 1080p to 4K. smooth playback.
RTX 3070 is way too powerful for video playback only duties.
I have a Samsung Qled Q95 75 inch TV, so its not a slouch !Don't the most current "4K" TVs already do the upscaling to their native 4K panel default?
Which is a better bet to do this (upscaling) function? The VideoPlayer or the TV?
I am guessing the TV knows best!
Kodi, when run and setup correctly with DSplayer engine, takes control of your PC. It controls your gpu in exclusive mode too.In the earlier days of 1080p video watching - before HTPCs - I was using the Patriot BoxOffice PBO/Core, and then PBO/Alpine boxes!
Next, I was using BSPlayer, over the standard-bearer of the times called VideoLANClient, that was reborn as VLC.
Both were much better than the Microsoft "WiMP"; yet, both were cumbersome for my HTPC needs (imo).
QuickTime, XMBC-Kodi, GOM-player (et al) also did not work out for my growing needs.
The 5KPlayer was promising but did not work as well as the ZoomPlayerMAX, I currently use.
The amount of CODECs that are routinely updated (including MadVR) number in the dozens, for the PAYware ZoomPlayerMAX.
The new-ish ZoomPlayer 'CODEC auto-detect' feature cuts thru the clutter but its "advanced features" are quite bewildering yet become manageable.
Finding subtitles (different languages) is a manual task that is best done with other utilities.
I'll give the new Kodi-DSPlayer fork a try.
But at the current time, I am biased (some may call it apathy) towards my ZoomPlayer.
OT?: Even with admin rights; Window11 does not make it easy for users to change which apps control which extensions, and the number of audio/video file extension get all messed up when a new/different Video (or audio) player is installed in the system. All software-hell breaks when uninstalling a piece of AV software/utility/app.
I use RevoUninstaller to trace/log, during any software installation in my Win11P and RevoU seems to do a pretty good job tracking the "association changes", along with any Registry changes, to undo the harm that rogue-software leave behind with most standard uninstallers packagers (including that @#$% WiseInstaller).
Thank you @Ken Tajalli, for all the info.Kodi, when run and setup correctly with DSplayer engine, takes control of your PC.
Not only Kodi but its DSPlayer part (that is supported by one person) seem too hi-maintenance for me....The new-ish ZoomPlayer 'CODEC auto-detect' feature cuts thru the clutter but its "advanced features" are quite bewildering yet become manageable...
You will master it eventually !Thank you @Ken Tajalli, for all the info.
I dug a bit deeper into Kodi/DSPlayer (and its forums).
I realized that it really is for the videophile, whodoes not mindlikes tinkering, tweaking, and optimizing their video streams.
I went thru some of those types of engagements for far too long, in the early days of computers+video.
Nowadays, I just want to sit down and press few buttons to enjoy watching a movie.
