How to disable power savings in Linux
rentaclaus
As power-saving is quite often the root cause of distortions or malfunctions in sound here my collection of possibilities to disable power-savings. All commands are for Ubuntu, you may have to change things according to your distribution.
Feel free to complete the possibilities...
1. Disable power saving in Pulseaudio
Edit /etc/pulse/default.pa and comment the following line:
load-module module-suspend-on-idle
by adding # in front
Result:
# load-module module-suspend-on-idle
Then restart the sound server.
"systemctl --user start pulseaudio.service pulseaudio.socket"
2. Disable power saving in Pipewire
copy alsa config script
"sudo cp -a /usr/share/wireplumber/main.lua.d/50-alsa-config.lua /etc/wireplumber/main.lua.d/50-alsa-config.lua"
edit /etc/wireplumber/main.lua.d/50-alsa-config.lua
Line
--["session.suspend-timeout-seconds"] = 5, -- 0 disables suspend
gets
["session.suspend-timeout-seconds"] = 0, -- default is 5
restart wireplumber
"systemctl --user restart wireplumber"
3. Disable power saving for soundcard/USB
First check what you have
"cat /proc/asound/modules"
Output e.g.
0 snd_hda_intel
1 snd_usb_audio
Check if power-save is enabled
"cat /sys/module/snd_hda_intel/parameters/power_save"
or
"cat /sys/module/snd_usb_audio/parameters/power_save"
if the output is 1, power saving is enabled
Check if disabling helps
"sudo echo 0 > /sys/module/snd_hda_intel/parameters/power_save"
or
"sudo echo 0 > /sys/module/snd_usb_audio/parameters/power_save"
If distortions(noise, buzzing, crackling ...) are gone, make it permanent
execute
"cd /etc/modprobe.d"
create a new file named audio_disable_powersave.conf and open with text editor (e,g, nano)
"sudo nano audio_disable_powersave.conf"
insert (depending on souncard)
options snd_hda_intel power_save=0
or
options snd_usb_audio power_save=0
save
reboot
NiagaraPete
NiagaraPete
load-module module-suspend-on-idle by adding # in front
Result:
Line
gets
restart wireplumber
Output e.g.
0 snd_hda_intel
1 snd_usb_audio
or
or
execute
or
save
reboot
Thanks very useful.
