How smooth can in room response realistically get?
Mawclaw
The ATL
I have spent some quarantime getting the system dialed in with room treatment and using Dirac. I really like the sound now, but will likely keep messing with it compulsively.
A few questions-
-Is the moving mic method (below) the best way to get accurate data? So far it seems the most repeatable- but does it over average or hide issues?
-Is it possible to get +-2 dB of target curve in room without a purpose built room?
-Are there any glaring problems below? KH310 and some absorption on ceiling, floor and rear.
-Any other information I should be looking at beyond frequency response?
DanGuitarMan
Jersey City, NJ
That looks awesome! Good work. I don’t have any answers to your questions unfortunately.
I will tell you I’m getting slight shifts in my daily mmm measurements. I haven’t figured out why. Some parts of the spectrum line up day after day, while others change here and there. So I average them all together, and I like the eq changes better from the average, rather than one measurement in isolation. I’ll make a separate post about this someday.
Balle Clorin
Let us know what speakers, placement, room and other remedies you use beside Dirac
Edit: I will read better next time, what is your speaker and listener positions?
DJBonoBobo
any germ
@Mawclaw Awesome, indeed, and much better than mine (see below). I also use KH310 (+KH750 sub). No Dirac but heavy EQ below 100Hz. Some passive absorbtion. But in my case its a small room, desk and screen between the speakers and a window behind the speakers that messes with upper bass/lower mids.
I like the RTA MMM-method, but i´m not getting completely reliable results. But in my experience it´s better than single measurements and more practical than Dirac-style multi-measurements.
RTA MMM:
M
Mawclaw
The ATL
Please excuse the messiness of my office and the overall ghettoness.
Room dimensions 21' Deep 7.5' Wide and 7'10'' Height
The setup that I found worked the best so far-
KH310's close to the walls. Around 6 inches.
Listening position 5ft away. I found this by measuring several different distances from the monitors.
Absorption panels that block desk reflections- extremely ugly.
Absorption on first reflections vertically and on back walls. Nothing really on the sides. All of the panels are 2'x4' GIK panels that start absorbing at ~900HZ. I have stacked them on top of each other in the rear for "bass traps".
Here are some pictures. I had to take down the cloud because it was scaring me with the janky installation. I think I have to fabricate something that is sturdy before hanging it over thousands of dollars of electronics.
M
Mawclaw
The ATL
RTA MMM:
Damn that low end looks really good! Especially for the small room. Is there a reason you don't EQ above 100? I have Dirac working below 800 but don't really have a reason for that.
Also how do you like the KH750? Was it a good upgrade? I have been considering subs recently
QMuse
A few questions-
This looks really good. Can you post how your filters are looking?
DJBonoBobo
any germ
Thanks! I had my own thread about optimizing bass in my room a few days ago (https://www.audiosciencereview.com/...bwoofer-and-eq-also-passive-absorbtion.12264/). You can see there that adding a sub was the most important element for getting a good response in my room. BTW i ended up using the manufacturer-recommended settings for the sub (delay derived from distance) but got motivation to find a better position and find better eq-filters.
Honestly i don´t see much room for a better bass response in your setting. I don´t know if the sub will do much for you. I think your low end looks really good.
The KH750 is also great for the KH310 because of it´s DSP-functionality but you don´t seem to need that.
I own a Dirac-license, too, but i stopped using it for practical reasons.
I don´t EQ above 100 Hz because this range is quite volatile in my room, because i´m moving my desk and my screen around and i just don´t want to think about it all the time. The higher the EQ gets the more i´m questioning what it does when i´m listening to music.
Also, to get back on your topic, i found interesting the room-response measurements by Sound & Recording. KH310 is not available, but this is KH80 (Average of multiple measurements, blue without filters, red with EQ; source: https://www.soundandrecording.de/equipment/studiomonitore-neumann-kh-80-dsp-die-messdaten/):
QMuse
You may want to check here as a demonstration what can be measured with MMM.
vavan
Kazan, Russia
Pio2001
Neuville-sur-Saône, France
Not much. But it may hide the variability of the frequency response from one point to another.
For example, here, we have a multipoint measurement, where each curve represents a single-point measurement taken in a +/- 30 cm area :
We can see here that the frequency response at 120 Hz and 180 Hz is very stable, and can be accurately equalized.
But around 100 Hz, it is a complete mess.
The MMM curve is much more useful and accurate, but you can't see this information.
Yes, that's not a problem.
The problem is to know if your default target curve is itself +/- 2 dB away from where it should theoretically stand, given your speakers and your RT60.
It looks great !
You make me think about this comic from xkcd :
M
Mawclaw
The ATL
Thanks everyone!
Could you elaborate on this or give me some reading material? Specifically on the RT60 effect
Last question- I am considering adding some subs to add low end punch and extension. What is a proper crossover point or how do I go about sorting integration without just brute force measurement.
QMuse
Where should target curve "theoretically" stand?
Personally I never heard that RT60 is related to the target curve. Do you care to explain how exactly?
QMuse
Most mains/subs combos would have XO at 80Hz or somewhere close to that. You can't do proper integration without measurement.
jlo
The target curve depends on how you measure. With MMM, you get a mix of direct sound and diffuse soundfield. This later soundfield results of loudspeaker power response, listener distance and frequency dependant room absorption, that is more or less the frequency dependant decay time (not exactly the RT60, I agree).
I did an online calculator here : targetcurve
I would be interested to know if the calculator agrees for your setups, loudspeakers and rooms.
QMuse
The target curve depends on how you measure. With MMM, you get a mix of direct sound and diffuse soundfield. This later soundfield results of loudspeaker power response and frequency dependant room absorption, that is more or less the frequency dependant decay time (not exactly the RT60, I agree).
Target curve doesn't depend on how you measure, it is the curve you equalize uncorrected measured curve to. In other words it is the curve showing how you would like your corrected response to look like.
Absorption and decay are two very different things. RT60 curve is showing how much time sound takes to decay for 60dB over the frequency range.
jlo
Maybe my words were not precise enough...
Frequency response depends on how you measure : use MMM, use single point or multipoints average, use fixed or frequency dependant windowing , measure at one meter or at listening place, measure in a living room or in an anechoic room, all methods give different responses.
That also means that the target is dependant of the way you measure : ie it could be nearly flat when measured with MLS or sine sweep and a FDW window or with a slope when measured with MMM..
There is no real RT60 in a normal room : diffusion is never uniform enough. You allways measure a decay, and generally only a 20 or 30dB decay (extrapolated to 60dB). This decay is representative of the room absorption and directivity of the loudspeaker.
QMuse
Maybe my words were not enough precise...
That also means that the target is dependant of the way you measure : ie it could be flat at one meter and with a slope at listening place.
Well, you have now stated a bunch of obvious things with which I surely agree, although I am not sure why you stated them. However, I think decay is primarily room characteristic and doesn't have pretty much anything to do with speakers directivity. Practically every speaker's response will experience the same decay characteristic if put in the same room.
