Fosi BT20A Pro review
ram0807
Netherlands
BT20A Pro - https://www.fosiaudio.com/product/2-1-channel-amplifier/bt20a-pro/
Review , How so Early? – Got opportunity to be a beta tester and received it free from Fosi ( via their FB page).
Review in my simple/basic/practical parameters:
Test time – 40 days , it was plugged on almost the entire period .
Speakers used – Linton Heritage 85 Wharfedale , Jamo S805
Audio Quality - *****
Bluetooth - *****
no noise at standby ( when you disconnect your phone)
Connects easily
Capability ***** , Drove my speakers with ease.
Size ***** , though it’s a bit bigger than the normal version but still very small compared to my Denon amplifier.
both my speakers had enough Bass , so sid not try the pre-out
was waiting to check the release price before giving the stars .
its definitely a 5 star product with the price tag , and even keeping the price aside its a very good product.
5* BT but not Aptx? Really? What music do you listen?
Yes , it's mostly to the quite and distance feature
Am only listening to Music , I think aptx would be mak9ng difference for videos for lip sync
I listen to
Rema and Louis fonsi and black pink kind of stuff
