Hello future friends and foes,
I'm about to dive into installing Foobar2000 for the first time in 64 bit on Windows 12 in V2.
I'll be playing back high-bitrate audio files from either HDTracks / ProStudioMasters or my own collection from records that I've worked on, through a Lynx Aurora (n).
Would you recommend installing Foobar either in standard or portable? I won't be using it on a different machine but having everything in one folder sounds somewhat enticing.
Would there be any drawbacks from installing it in portable? Especially using it with the ASIO component? And general stability compared to standard?
It's probably also easier to wipe the slate clean after custom-tinkering around with it in portable?
I also don't want Foobar to associate file types with it, such as .wav or .aiff.
Are there any good looking themes that work with V2 in 64-bit?
Are there any components you'd recommend as a must-have?
I'd chose to stick with ASIO for playback since I'm using it with Pro Tools on a daily basis.
Oh before I forget, is there any conflict with DAWs when installing the Foobar2000 ASIO component? Could it brick my Pro Tools ASIO compatibility? It's probably highly unlikely but I'd rather ask the question than not.
Thanks in advance to everyone taking part in my topic.
