I just received my Moondrop Blessing 2s in the mail from Amazon.
So when I plug them in to my 1/4 port on the topping DX7 Pro I get a constant whine noise. This noise is unaffected by the volume level of the amp.
It sounds one way at idle, another way when I move the cursor, and constantly changes pitch during gameplay depending where I'm looking or what's being rendered.
Because of this I believe it is EMI from the GPU of some kind but I'm not absolutely sure.
I plan to get a new A90 Discrete and running balanced from the DX7 Pro DAC to the A90. Would this solve the noise problem?
Is there anything I can do to solve it in the meantime? I really like these IEMs and I want them to work ASAP.
Is it possible the IEMs are at fault?
