deprogrammed
Element III MK2 = New Knob and EQ Firmware – JDS Labs Blog
blog.jdslabs.com
This looks interesting. From the above link:
Each equalizer band involves a parametric biquad filter, processing on a dedicated core in near real-time, with Q = 0.707.
Each band allows up to +/-30dB of gain adjustment at 8 possible frequency choices. We’re now memory constrained, but have the option to compile different cutoff frequencies upon request:
Bass Frequencies: [40Hz, 60Hz, 80Hz, 100Hz, 110Hz, 125Hz, 150Hz, 170Hz]
Treble Frequencies: [10kHz, 11kHz, 12kHz, 13kHz , 13.5 kHz, 14kHz, 14.5kHz, 15kHz]
DSP settings are stored separately for Headphone Output and RCA/Line Output, and the DSP cores are bypassed entirely when gain values are set to zero (default). You will also see “DSP Active” displayed when DSP cores are in-use.
