- Joined
- Jun 5, 2016
- Messages
- 2,878
- Likes
- 4,699
He's lying or just a buffoon.
That’s not fair or accurate!!!
You need to change the “or” to “and.”
I'm not sure why you addressed me. Kongwee contends that everything reaches the tweeter, including the midrange. It's a dumb argument and I'm going to stop discussing it.No it won’t. The tweeter is not going to emit a 50/60Hz or 100/120Hz hum. It will therefore not affect the polar pattern. The contention here is that a low frequency signal of sufficient amplitude will affect the tweeter’s ability to reproduce high frequencies with low distortion. Whether or not that is true would depend on the driver. In any case, the simple answer is: don’t use amps that hum in active speakers! Or anywhere for that matter.
I did not address you. I quoted your statement and disputed it. I don’t care about your tussles or historical arguments with other ASR members.I'm not sure why you addressed me. Kongwee contends that everything reaches the tweeter, including the midrange. It's a dumb argument and I'm going to stop discussing it.
Uh huhI did not address you. I quoted your statement and disputed it. I don’t care about your tussles or historical arguments with other ASR members.
Uh huh
I'm ignoring you because you're misattributing me. I don't know if you're trolling, or what.Not sure what you mean. When I got my education, science and engineering wasn’t about who said what, or who likes/hates whom, it was simply follow the evidence, be guided by the facts.
Back on topic, your assertion that low frequency artifacts ending up at the tweeter would show up in the polar radiation pattern of the speaker is not true. The tweeter would be unable to emit them at the required SPL. However, sending those low frequency artifacts to the tweeter may or may not affect its ability to produce clean HF output. This I believe was GR’s argument, for which I haven’t seen any evidence (I think a distortion plot would tell the story), but it certainly shouldn’t be dismissed purely because Danny‘s been talking a lot of nonsense in the past.
I think that is what Danny thinks, yes.However, sending those low frequency artifacts to the tweeter may or may not affect its ability to produce clean HF output. This I believe was GR’s argument, for which I haven’t seen any evidence (I think a distortion plot would tell the story), but it certainly shouldn’t be dismissed purely because Danny‘s been talking a lot of nonsense in the past.
This is what I think:Back on topic, your assertion that low frequency artifacts ending up at the tweeter would show up in the polar radiation pattern of the speaker is not true. The tweeter would be unable to emit them at the required SPL. However, sending those low frequency artifacts to the tweeter may or may not affect its ability to produce clean HF output. This I believe was GR’s argument, for which I haven’t seen any evidence (I think a distortion plot would tell the story), but it certainly shouldn’t be dismissed purely because Danny‘s been talking a lot of nonsense in the past.
I never used a capacitor, in 30 years I have not blown a tweeter.If there is no such capacitor it means the engineer was confident that either there aren't any LF artifacts in the first place, or they don't matter.
Same for the woofer
Some amps have huge turn-on and turn-off thumps. I've talked to people who had tweeters destroyed by that.I never used a capacitor, in 30 years I have not blown a tweeter.
Using a capacitor messes with the whole idea of precise frequency and phase control.
a big turn-on and turn-off thump is a big red flag for a terribly designed amplifier.Some amps have huge turn-on and turn-off thumps. I've talked to people who had tweeters destroyed by that.
Well, sort of. A solution is an output relay that only closes when the output stabilizes. That's what a lot of amps do. It's a rare amp that doesn't have some thump. Generally no one cares a lot because woofers are kind of indifferent, within reason.a big turn-on and turn-off thump is a big red flag for a terribly designed amplifier.
ORWell, sort of. A solution is an output relay that only closes when the output stabilizes. That's what a lot of amps do. It's a rare amp that doesn't have some thump. Generally no one cares a lot because woofers are kind of indifferent, within reason.
JBL thinks it does, in any event. They suggest a value that places the pole an octave below the crossover. Me, I just bought an amp that only has about 1mA thumpOR
leave it on 24/7 - as we did.
And a big capacitor hardly helps anyway.
Howdy are you trolling here? Seriously, an active speaker uses active filtering. That is why it is called an active speaker and an active filter is called 'an active filter' because it use power(needs to be plugged in). Passive filters are called such as they filter without needing additional power supplied. This is not complex. Sorry, I have to assume you are trolling, if not so be it. These GR based threads!Not wrong if the active speaker do not filter the unnecessary frequency for the drivers. All ASR review doesn't tear up the studio monitor to measure if the driver are receiving full range or filtered frequency.
To which i said, even in an active speaker, one would certainly protect a tweeter from all that low frequency nonsense with a capacitor.
Engineer, thinking about LF artifacts, 1974, colorized.
Diving a bit deeper, this protection cap typically needs to be 20 uF or more. Could easily be twice that depending on crossover frequency and filter order.
Those are BIG caps when you buy something nicer than an electrolytic.
When pushed to it, I've used polypropylene motor run caps.Diving a bit deeper, this protection cap typically needs to be 20 uF or more. Could easily be twice that depending on crossover frequency and filter order.
Yes, but we are talking background hiss levels of an amp in an active speaker, not high volumes of high frequency content.a big Woofer can defintely produce high frequencies at high volumes.
