Ding ding ding! We have a winner.In other words, with active speakers, there's not much left for him to sell you.
That will show in the polar pattern, for obvious reasons.Not wrong if the active speaker do not filter the unnecessary frequency for the drivers. All ASR review doesn't tear up the studio monitor to measure if the driver are receiving full range or filtered frequency.
He's a known quantity here. Not in a good way, either.Oops. Didn't know it was already posted. I was just frustrated after watching the video. I did purchase his XO upgrade for the RP600m and that was my first intro inrto doing anything with speakers. I'm glad I did it as it fixed the giant dip in the xo and tamed the tweeter a bit. I'm sure the NO RES didn't hurt either. But this is just ridiculous.
What science can you base on polar pattern?That will show in the polar pattern, for obvious reasons.
Huh? Acoustics? What happens when you have two radiators broadcasting the same signal spaced apart?What science can you base on polar pattern?
Tweeter and midrange driver will still the same signal, and produce their own frequency response what so hard to understand? There are so many active that doesn't care about filtering frequency.Huh? Acoustics? What happens when you have two radiators broadcasting the same signal spaced apart?
Uh huhTweeter and midrange driver will still the same signal, and produce their own frequency response what so hard to understand? There are so many active that doesn't care about filtering frequency.
You should learn something about speaker design and acoustics before you bother people here with silliness. There are lots of acoustics courses that professors have posted online.Tweeter and midrange driver will still the same signal, and produce their own frequency response what so hard to understand? There are so many active that doesn't care about filtering frequency.
You should consider that there is a language problem and that you have to explain with more than just one keyword.You should learn something about speaker design and acoustics before you bother people here with silliness.
The latter.He's lying or just a buffoon.
I'm an engineer, not a teacher. I'm sure my "explanations" are lacking in any event.You should consider that there is a language problem and that you have to explain with more than just one keyword.
Always make sure the message is detailed enough, so that the receiving end has a chance to understand it's meaning.
If you're familiar with kongwee's posting history, language is not likely his biggest problem.You should consider that there is a language problem and that you have to explain with more than just one keyword.
Lol!!! Missed that one.If you're familiar with kongwee's posting history, language is not likely his biggest problem.
Here is an example comment on one of his posts by one of our most distinguished senior contributors.
Class A amplifier
Any real measurements instead of a spec sheet typed up by the manufacturer? Would be interested to see same. JSmith Just for our reference, Accuphase always shows their "guaranteed" THD and Fq response spec data in their users manuals, like this for Class-A amp A-75...www.audiosciencereview.com
Firstly, the guy is talking rubbish.Can you name an example? I wasn't aware there are such speakers.
Um... they work by sending filtered signals to each driver. That's what an active crossover does.Not wrong if the active speaker do not filter the unnecessary frequency for the drivers. All ASR review doesn't tear up the studio monitor to measure if the driver are receiving full range or filtered frequency.
Both.The latter.
Seems you're right ! I was given a few defective Dynaudio active studio monitors and I found the same problem in each: over heated circuits !I would say the main issue for active speakers is limited space and ventilation. Its not easy to squeeze so many components into a small space.
If it is properly engineered there is no problem. Why do all the studios and live events use active if they would constantly overheat?Seems you're right ! I was given a few defective Dynaudio active studio monitors and I found the same problem in each: over heated circuits !
As did i. ;-)Lol!!! Missed that one.
