I have already build a Diy dual opposed subwoofer with 12 inch Scan Speak Discovery drivers and Hypex fa501 amp it sound very good.
The drivers share a 53 liter volume with a lot of wool to have a higher Qtc.
But now i have another pair of the same used Scanspeak drivers.
Im planning to build another Dos subwoofer with the bigger fa502 amp 2x500w@4ohm.
Its maybe better to give each woofer his one sealed enclosure with that amp?
In parallel conection with the fa501 amp that was not necessary.
Planning to build the subwoofer 48x50x40cm each woofer has then a seperate 28 liter volume, with a lot of wool the Qtc wil be arround 0.78
In that small box the driver can handle all the power from the Fa502 without over excursion i think.
Sombody advise of other thoughts about this project?
