Jamproject
- Joined
- Jan 18, 2025
- Messages
- 10
- Likes
- 2
Hello,
I built zaph audio zrt about 10 years ago and now think of upgrading them, both from the aestetical (current painting is average) and performance point of view.
I would like to share and have your opinion about the upgrade.
What I'm planning to do is to make the column as two separates parts :
- The actual ZRT in a closed box of ~20L without further modifications (same passive filter) just eventually a slight increase of baffle width (something like 1cm shouldn't be very significant right?) and slight edges rounding.
- A subwoofer "stand"
For that subwoofer, I would like to go dual opposed side firing in a sealed configuration with DSP equalization. I would drive them in mono.
Something like above:
Depending on the depth, volume would be 22-28L which is not a lot for 2 drivers.
The depth of the drivers itself is also limited to ~12cm which eliminates a lot possible choices to.
I identify solutions while playing with WinISD:
- SB Acoustics SW26DBAC76-8: 250€ each, Qtc=0,669 in 22L. It's a shallow subwoofer and seems to perform well but don't know how it compare with similar prices non-shallow subs.
- PEERLESS XLS-P830452 (width increased to 25cm): 170€ each, Qtc = 0,593 in 22L. I don't know the performance but I read Peerless subwoofers was great in general? The problem with this is that it is a discontinued product. Don't know if it's a good idea to buy 4 of them..
If anybody have an opinion on which one is the best performer?
Is someone aware of an other solution?
Here is the max SPL (2m) simulation for 2 drivers - but the final objective is to have 4 - RED is SB ACOUSTICS
And frequency response:
Regardings the electronics I would replace my Wiim pro plus + amp with a Wiimp amp pro, which have a subwoofer output and dsp for equalization.
And to drive the 2 subs maybe a hypex NC502? Maybe it's overkill and cheaper options are OK? Diy is an option for this to if a cheap good performing amp module exists somewhere.
Thank you for sharing your thoughts
Have a good day,
Have a good day,
