DSD to PCM Conversion
Zog
I have a lot of DSD files. I have converted some of them to PCM using Foobar2000. I have two questions I hope you guys can chip in with. The first: Is there any sonic benefit to doing this?
Second, is there any other software that does this?
(I am not interested in the space saving from a conversion from DSD to FLAC. Also, different tagging is not important.)
Aside from storage, there is the benefit of being able to apply digital EQ that wouldn't be possible if you did direct streaming, but I think that's it. DSD purists will say that converting to PCM defeats the entire purpose of the format (I'm not considering the possible different masters used), as it is meant to be a bit perfect "solution".
Other software I use to convert DSD to PCM is Musicbee, but I think Foobar2000, when configured correctly, may offer more options. I just personally prefer Musicbee's interface and the way it gets rid of the gigaton original DSD rip file automatically (If it set it to do so).
Why? Do you not have a DAC capable of playing these natively? If not get one. By my pretty basic understanding, the cheapest Topping (or most chi-fi) will play these wonderfully. Just use ASR electronics index to pick a relatively new one. Pay no attention to the throngs of naysayers, in regards to DSD. You already have the files, just enjoy them. Storage is cheap (and likely to get vastly cheaper). If you must listen to the ravens of audio purity, just accumulate new music in the format you like best.
You can't "improve" the sound and I'm not an expert but I believe that's always mathematically imperfect and not perfectly-mathematically reversible. The formats have different limitations but both can be better than human hearing.
And it can be an audibly perfect conversion and a "normal DAC" requires conversion to PCM anyway.
Most DSD recordings were originally recorded and mixed in PCM. 24/96 PCM is the default pro studio standard. Most ADCs are 24-bits and virtually all DAWs (and other audio software) uses floating-point PCM (at whatever sample rate that matches the recording).
Technically converting DSD to PCM is lossy but the loss is so small. There's also the fact that most DSD recordings are just DXD. In terms of sonics, some DSD albums have lots of high volume noise above 30khz which can kill your speakers faster, even if its been converted to PCM. Luckily its real easy to install filters on the software and use filters on the hardware side to defend your self against the noise but If your still worried about it, you could convert your DSD albums down to 44.1/16, 44.1/24, 48/16 or 48/24.
In the future, if your ever worried about space, you could convert your DSD albums to WavPack DSD which cuts the size in half losslessly.
That's another point. What is the best sample rate? My tweeters are rated to 50Khz (Magico A3). I have been going to 24 88. But 24 48 could be a good option too. Is it a concern that 48Khz is not directly divisible into 88Khz?
I should have mentioned that my DAC (Matrix Audio X-Sabre Pro) can play DSD directly via USB (and by DoP via USB and I²S - though I don't see much point in that.)
You've obviously mixed up the frequency range of the tweeter with the sampling rate of the audio file. These two values have nothing in common.
I would say it depends on the music. Some DSD albums are just converts from CDs while some DSD albums have actual data over 24khz. Then there's that whole debate about music affecting our bodies even above our hearing range.
The way you convert to PCM matters more then what frequency/sample rate you use.
You have obviously mixed up being informative with being insulting. What is wrong with you man?
One sensible use case for converting DSD to lower-resolution PCM would be to take files you've bought from a high-res vendor like HDTracks and convert them to 16-bit/48kHz FLAC files to play in your car. Or maybe even convert them down to 320kbps MP3 files for car use. The road noise pretty much negates the need for super-high-res audio anyway, right?
If you're worried about the high frequency noise from DSD files, you can convert to 24-bit 88.2k Hz PCM, and the Nyquist frequency will then be 44.1k Hz. No frequencies higher than just below the Nyquist frequency should play from the 24/88.2k PCM file, assuming the playback device applies a suitable filter to remove the Nyquist frequency (which it most certainly should).
What foobar component needs to be installed to convert DSD files (*.dsf) to PCM flac or wav files with user-chosen bit depth (16, 24) and sample rate (44.1k, 48k, 88.2k, 96k, etc.)? I just installed foobar2000 and I'm setting up the components. I can't find usable information from an internet search or AI on the subject. Hopefully some kind person here can post a link to a good article or perhaps explain it quickly. Much appreciated. :)
