Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
3 dB per doubling of distance was intended to be used to find how much the rear array should be attenuated. I started out at a calculated value of 8.5 dB, and ended up very close to that with 9 dB.
Huh, that's weird. I was under the impression that in these setups the front and rear arrays should play at (or very near) the same volume, regardless of distance. (In theory there should be minimal losses from a LF plane wave as it travels across the room because it's not expanding at all.) It's hard to argue with the results posted, though! Can you confirm that the rear array is physically playing 9dB quieter than the front?
Thanks for the confirmation! That’s an interesting data point for sure. 9dB is quite a lot of loss for one traversal of the room. By some rough math (7m / speed of sound) * (60 dB / 9dB) that implies a room RT60 time of 135ms, which would be very low for LF. A bit of a mystery
I got confused by having amps with different gain for front and rear array, as well as different number of speakers on each amp. My math was not correct, obviously…
The idea is to extinguish the wave at the rear wall by adding the exact inverse to it. Since you have losses from front to rear, the rear needs to be attenuated to make that happen. So, this is exactly as expected.
Front end - including MG 3.7 with 4x12" midbass dipoles, MG 3.6 center channel with two 4x10" midbass dipoles. The whole thing is usually hidden behind drapes and a projection screen, so it's a bit less ugly than this (see pic #2).
Rear end, also showing the surround speakers - MG 3.6 plus 4x12" midbass dipoles - and hush-box for my projector. The large stack of firewood is actually "skyline" diffusors.
Couldn't one flush mount all the drivers in a gypsum board wall maybe? (Like cutting 50-50cm from the room in the front and the back)
That would make it kind of an infinite baffle I guess.... just an idea, not sure if/how DBA would work then
It could be much less. In real life, windows and doors can interfere with this dream)). For example, I don’t have a single wall without doors or windows.
I cross that high because the MG bass panels have increasing distortion levels below 500 Hz. They loose a lot of sensitivity as well, as much as 10 dB difference between 500 Hz and 100 Hz.
