Deleted member 58670
Guest
- Thread Starter
- #81
Eh.. What was the question?
Theoretically it should measure the same, unless maybe you get too close to one surface (sides or floor, in the case of "leg area")? This is because the reflections off the sides/roof/floor are meant to be symmetrical and all compliment each other (in terms of peaks and nulls), and so sum to a nice even plane wave. Then that wave moves to the back of the room and gets cancelled by a new plane wave. Therefore it should be nice clean plane wave everywhere, and actually the original plane wave could be considered "direct sound" because you don't hear it bouncing around the room in every direction (hence the cleaner waterfall etc).
Mine might get lost:Since there is a big attenuation on the rear array with an MLP closer to the rear wall,
do you guys think that smaller subs could be used there? (by Sd or Xmax)
What do you think of using « smaller" subs for the rear array? (smaller in Xmax or Sd)
This statement is not correct. The rear subs need to match the SPL of the front subs at the rear wall, because this is the point where they output the inverse wave.- if MLP is equally distant from front and rear walls, front and rear subs need to have the same SPL.
Very nice. Can you share the mdat file please, so that we can peruse the time based graphs?
About using smaller speakers/drivers on the rear, I've previously had the same thought, and I started a thread the other week - https://www.audiosciencereview.com/...-experiments-with-extra-tower-speakers.55698/
I haven't got around to testing it yet, but I've got it all physically set up ready to go.
Damn this is impressive! You don't happen to live close to Oslo do you, cause I would really like to have a listen something like this![]()
If the sub is flush, it only has 1 "direct wave" that moves away from the wall (when considering what happens front to rear). If it's not flush, then there will be 2 waves - 1 that goes to back of room, and 1 that goes to front of room and bounces off the wall. If it's very close to the wall, that bounced wave will be pretty close in time to the other wave, so it will probably still work. That's my understanding of it.- Do the subs need to be soffit mounted?
John Brandt uses convex rear wall in his control room designs. https://gearspace.com/board/studio-...809ca0d89c9eb7f42e41d47880dd5ed6#post17120653Obviously that convex protrusion in the rear wall has to go for a DBA to work.
