Because there is no independent audio-visual room, a home theater is built in the bedroom. Because of the need to consider daily life, too much acoustic decoration cannot be done on the surface. Is it useful to put sound-absorbing materials in the ceiling gypsum board, or must the sound-absorbing materials be made on the surface?
- Pictures deleted -
Suggested installation:
1) One layer of drywall on the ceiling.
2) Fill the space between the drywall and the concrete ceiling with fiberglass insulation
Sound will travel upward through the drywall and be partly absorbed broad spectrum by the approximately 12-inch (30cm) thick fiberglass layer. The broad-spectrum sound absorption is a very nice feature of this system. Some sound will of course be reflected from the ceiling drywall back into the room.
Some sound will then travel upward through the concrete, much of the sound will be reflected downward by the concrete.
Broad spectrum sound will be absorbed on its way back down toward the ceiling drywall, some sound will be reflected by the drywall back into the fiberglass to be absorbed. A very reduced level of sound will move downward through the drywall back into the room.
3) The room appears to be part of a large concrete structure. The structure will absorb and transfer vibrations from impinging sound, direct vibration transfers from equipment such as refrigerators, HVAC, washers and dryers, exercise equipment, and impacts mostly on floors, from all parts of the entire structure. Some of these vibrations will be transferred to the air below the concrete ceiling as sound and proceed downward. The fiberglass layer will absorb much of this likely low frequency sound.
4) Much of the sound that enters the room from the walls and windows will hit the ceiling where a portion of this sound will be absorbed by the insulation in the ceiling. The concrete box that is the room will encourage sound to build up at various frequencies. The ceiling absorption should significantly reduce these buildups.
