Do ohm resistors help the sound for high impedance amps and ear buds?
Dunring
Florida
I've been checking out some of the 3.5mm adapters that provide resistance since I've gotten into low ohm IEM's lately. Couldn't find specific information on what they drop the ohm rating to though. Some amps like the SMSL SP200 output 12 ohms, so trying to determine if they would prevent changing the sound of something like 10 ohm IEM's. I see how they could help to bring up the volume up on an amp for better channel matching, but has any measurements of their output impedence after the adapter been done?
DVDdoug
What?
Low source impedance from the amp is better. That spec isn't always published. Usually they give you the recommended minimum headphone load impedance.
If the source impedance is not low enough relative to the load, the voltage drops with lower load impedance. That causes frequency response variations because IEMs, headphones, and speaker impedance varies over the frequency range. And if there is a DC blocking capacitor on the output, that acts as a high-pass filter (DC is zero Ha) and with lower impedance the cut-off frequency is higher and you can lose bass.
It's the same with power amplifiers... 4 or 8 Ohms is the load and usually the amplifier has a source impedance that's a fraction of an Ohm. If there is a spec, it's given as the damping factor.
IEMs, headphones, and speakers are measured/specified with a "constant voltage" source (a source that's independent of the load).
RandomEar
The SP200 has near-zero output impedance. Amir found no problems with it in the review.
solderdude
The Neitherlands
Some IEM's actually sound better with some specific series resistance. This is a technical thing where the ratio between the impedance and output R changes the frequency response to a 'nicer sounding' one.
This certainly isn't the case for most IEMs. They are designed to be driven from low output R sources.
These series resistors will also attenuate.
That could be beneficial when an amp is relatively noisy and the IEM is very sensitive. This way you can lower the noise level heard (from the amp) and you will have to set the volume knob a bit higher in that case.
That could also be handy when your volume control is used in the lowest range where you could experience channel imbalance (varies per volume control setting)
These simple resistors can be used for that BUT the high resistance value can alter the frequency response of said sensitive drivers and can do so in a negative way.
When the goal is to counter selfnoise of an amp/source and or get a more usable volume control range it would be better to use an attenuator (resistor network with 2 resistors).
This can A: lower the signal in a much more significant way and B: ensure a 'good load' to the amp and ensure a low source resistance as 'seen' by the driver ensuring the frequency response (tonal balance) is not changed.
