Dirac Reviews
As far as I know, REW only allows you to create all-pass filters with "falling" phase, which are not suitable for counteracting the crossover-related phase wrap. So I guess rePhase would be the better tool to use for this purpose.
To get a "perfect" looking impulse and step responses you need to correct the excess phase which is introduced by the crossover, which in turn aligns the tweeter and woofer responses.
E.g. here's a comparison of the impulse and step responses of the original measurement, vs the minimum-phase version of the same magnitude response:View attachment 384729View attachment 384730
So if you're able to calculate a filter that counteracts the crossover-related excess phase part of the response you will get the nice-looking impulse/step responses you are after.
The way I tried to do it:
  1. Open a measurement in REW and apply some (strong) smoothing to the frequency response. I used "1/1 smoothing" in my test.
  2. Click "Actions" > "Estimate IR Delay" and then shift the IR accordingly -> this will remove the phase wraps introduced by the delay of the measurement system, including the delay introduced by propagation of sound through air (from speaker to mic).
  3. Click "All SPL" view, then go to "Actions" > "Measurement actions" > "Excess Phase Version" -> this will create a new measurement with flat magnitude response and only the excess phase component of the original measurement
  4. Export the previously generated 1/1 smoothed Excess Phase measurement and import into rePhase.
  5. In rePhase we're aiming to get the phase close to zero in the mid and high frequencies. It seems to me that aiming for flat phase between 1kHz and 10kHz gives pretty good results for this purpose. Use the "Filters Linearization" view and add a filter to counteract the crossover phase wraps, and then add a few "Paragraphic Phase EQ" filters to tune as needed. My Revel M16 is specified with a crossover at 2100Hz, so I used that with a "LR 24 db/oct" crossover preset in "linearize" mode and then added just 4 paragraphic phase filters with relatively low Q values (0,5 or 1).
    This was the result:View attachment 384852
  6. Export the phase correction with the appropriate number of taps and sampling frequency (I used 2048 taps and 48kHz).
In my case, here's how this manual phase correction compares to Dirac (and original measurement without any correction):
So it is possible to get similar-looking impulse/step responses as with Dirac, but it might require a bit of experimentation with smoothing and choosing the frequency range where you apply the correction.
Just to note that if you overdo phase correction you can get audible artefacts like pre-ringing and such. Probably you also need to be careful about filter stability. I don't have too much experience with this kind of correction so I'll leave it to other members to chime in. Hope this helps!
This comes close to attend university classes;)
I got the impression that most people always like what the have (including me :facepalm:). They think that their home perceived sound is quite good. 99.9% never enterd a professional studio controll room ( besides probably some proffesional ASR members) from at least let say 1 million euro or dollar with a investment ratio of 70/30 which relate to 70% room treathment an 30% gear. On top of that most could probably not distinguished the difference between instruments (so how they must sound on a recording) like a Bösendorfer or Steinway piano's a Telecaster or a Stratocaster an so on. :facepalm:
Than we have seperation between instrument an voices in a well recorded session including the reverb time from the venu. In suche quality recording using the needed an correct placed quality mic's it contain the information for staging imaging for instance. I noticed (in my current mancave) that most of this is revealed with (a well measured) Room correction (DSP) if your room like mine has a horrible acoustic. I guess that 90 % has the same problem. So get acainted with the correct sound which means if you listen to a bad recording the DSP will reveal that without mercy (which means DSP does it job) if it is well recorded you could be in heaven with DSP. If you have a well treathed listening room you don't need DSP so atleast do a Propper measurment with REW for instance it reveal a lot. I use Mathaudio room EQ did compare it with Lyngdorf an Dirac quite similar sound/result all of them i noticed. DSP for me did let me rediscover my music collection.
From my experience, at home you get the best results with some physical room treatment in combination with DSP... A DSP alone cannot correct everything your room does to the signal. Physical treatment will allow your DSP to function even better and you will need less filter which will most probably add to the sound.
A / B
Moving from an early version of Audyssey XT32, Bass tightened up (marginal), midrange, vocals, dialogue became distinctly clearer, imaging improved marginally...
The old version of XT32, had no way to turn off the MRC (mid range compensation)... so it is possible that a current D&M implementation would provide the same benefits.
Be that as it may - Dirac has proven itself a worthwhile upgrade, and resulted in my setup sounding better than it ever has (not just in movie mode, but also in stereo, music mode)
Dirac is an excellent DRC system no doubt, but is also quite costly.
Included with most D-M processors, XT32 is FREE.
The $20 Editor app will allow you to turn off MRC, make individual curve corrections, and more. A real steal in DRC.
The $200 Audyssey MultiEQ-X is a highly configurable excellent PC based application and is capable of doing just about
everything the Dirac Live system can with probably equally excellent final results.
Both Dirac and X require a lot more hands-on work with fairly steep learning curves for the perfectionist.
A full boat Dirac upgrade in a D-M processor will set you back around $700.
It's all about the money and the effort you want to put in that will determine the end results.
A+
For me Dirac is a learning curb. I had a hard time getting the levels right especially the subs until I finally got it right. I recently got DLBC and can say it really made a difference in my bass compared to standard Dirac. Without bass control I had to raise the trim or gain afterwards. Now, at the same time my bass was likely not neutered this time because I got the levels right pre calibration. For example before the subs were -14.5 and -8 and now -5 and -3 or so. So it is hard to say if DLBC had a hand in this but I am loving my bass.
Agree that Dirac Live Bass Control takes time. Because of it, I upgraded to 4 subs and the bass in the sweet spot is excellent (3 measurement positions) with other spots very bassy. My 9 position measurement solved the over bassed spots but the sweet spot was not as good.
"A" rating for me. Soundstage is wider. In-room response curve is more level across all frequencies. More detail across the board and better base control, despite having pre-calibrated my subwoofer with its mic kit and software interface prior to using Dirac Live. Down-rated to a flat "A" rating due to using the "Direct Live Processor" version in tandem with JRiver Media Center and I then get distortion when minimizing the "Direct Live Processor" window while in playback mode. Minor inconvenience and I've written Dirac for their feedback.
Probably i missed it but do you use DSP for room correction if so what are you using.
I have Dirac Live on a MiniDSP Flex, to an old Adcom GFA-5500, on Revel F208 speakers and
I also have it on an Onkyo TX-NR7100 to a 5.4.4 setup of Mono Amber in-wall speakers.
The F208 setup sounded really good from the beginning. The Mono Ambers are terrible sounding, and have so much treble even at their -6dB setting they are borderline unlistenable. I did some frequency sweeps and they had almost 8dB excess energy at 4KHz, dropping like a rock after 12KHz.
Both systems now sound absolutely stellar. The F208 system lost a slight midrange edge on them and its M&K subs lost their "bass cloud".
The Mono Ambers went from almost unlistenable to absolutely amazing. At first I wanted to rip them off the walls. Now I simply forget about them and enjoy movies and music in Atmos.
A+. Dirac Live is a game changer.
A or A+, Dirac Live Bass Control on AV10 with 7.4.6 system. Three position measurements - my wife and I sit in a loveseat so a position for each outer ear and one for the two middle ears. 9 position measurements was better for the couches but worse for the sweet spot.
Hi, I bought recently an Integra DXR 3.4 that came with Dirac Live Room Correction. Coming from a Denon AVR that has dynamic EQ and volume I was hoping for something similar to make dialogue inteligibile at low volume. Couldn't find anything. It looks like Dirac tunes the speakers to play well at reference volume. Is there any easy trick to adjust the default curves to sound good at lower volumes?
I tried some Harman Kardon curves but those where quite different than what Dirac set automatically. Namely, there was one curve to apply to all speakers, while Dirac applies a different curve for each set of speakers (fronts, center, surrounds, etc). I have to admit that the automated Dirac set of curves sound pretty good at high volume.
You can adjust EQ manually to mimic ISO 226 bass boost shape far given SPL. It will work to about 65 dB SPL without adjusting the highs. Won't be automatic that's all. You can find (posted many, many times) on ASR for the neutral target output from JRiver ISO 226 2003 to see how much to add and where (knee is 105 Hz).
It will bring dynamics back but it won't make mids pop up in any way. Boosting them manually however will. I use multi gate compressor for that (PC).
If using Dolby Surround - you have the Late Night loudness mode
If using THX it has its own Loudness mode (but cannot be used with Dirac)
Thanks. I'll look into this. I wish Dirac was setting the default curve based on the desired loudness. I would have 3 calibrations: for 75db, for 65dv and for 55 db. Depending what level I wanted to listen to I would pick up the closest calibration.
Sorry @Snarfie, Old question but I did miss it till today.
I use Audyssey with the Editor app, running on my PC with Bluestacks android emulation software.
Makes it so much easier to make small curve adjustments than on a tiny phone screen.
I'm surprised Dirac doesn't include any form of dynamic loudness like DEQ ? Switchable Loudness compensation has been a feature
on much Hi Fi gear since the 1960s. I believe many forms used exaggerated over-emphasis to satisfy the usual craving for BIG BASS. LOL
From this it developed a bad name in audiophile circles which later got extended into even the use of any tone controls.
"Moderation In All Things" is still a very good path to follow. JMHO ;)
Been 2 years + since I used Dirac live full range. set up a new corrected filter this morning & figure out how to screen shot the damn graph so I can post it. I hit screen shot & it says auto saved. I checked file in computer & it pops up a bunch of jibberish. I manually saved project multiple ti,es & files have that jibberish inreadable content. I'm sure Ive done this before many times just can't remember how ?
If you are using a PC, hit the "PrtSc" button. Then you need an image editing program, like MS Paint. Hit Ctrl-V to paste it there, then save it as a JPG or PNG.
