I'm having a "minor" issue with my recently acquired DCA Stealth which is that there's a lack of bass but I've found that gently pushing in on the cups solves that problem, so it's a lack of seal / clamp pressure causing the bass to disappear into nowhere. No glasses, short hair and no beard - but maybe a narrow head, I'm not sure.
Without a proper seal on the Stealth, I feel like my HD660s has more sense of bass albeit with some EQ gain in that region. Applying gain to the bass on the Stealth does not solve the problem, bass remains absent, only more clamp pressure seems to do the trick.
This is a long shot, but have any of you tried modifying the nitinol wires to increase clamp pressure? Or found some other solution?
As far as I can tell removing the wires, attaching them to something so they bend a bit more and then heating them to something like 500ºC should work but before I go to such extremes I'd like to know if anyone else have had a similar problem and found a solution.
Thanks!
// Zap
Thanks!
// Zap
