ethanhallbeyer
- Joined
- Feb 24, 2019
- Messages
- 175
- Likes
- 50
i have a pair of class-d monoblocks with input impedance of 20 kOhms, output impedance of 70uOhms
my speakers are 1.7i Maggies.
i have tested 3 dacs, only one of which has a volume control:
1. RME ADI-2 DAC FS (has volume control). output impedance: 200ohms
2. Denafrips Ares II. output impedance: 2.4kOhms
3. Xiang Sheng DAC-05a. Line output impedance: 600ohms (i am using xlr out and not sure if it is the same ohms).
Source is iPad Pro via usb-c to usb-c/usb 2.x hub to DAC.
with the Ares II and DAC-05a, the Ares is considerably louder at the same volume. Volume is controlled by iPad OS software control. If I tick up volume to the first lowest setting possible, the ares is almost too loud, the DAC-05a less so.
could someone explain why the Ares II is considerably louder?
when the RME is connected, the iPad OS volume isn’t changeable. volume is adjusted by the remote control. -39db is where the RME sounds decently loud yet not so loud i am concerned about disturbing neighbors that share a same wall.
Thanks i'm advance
Thanks i'm advance
