Cornwall 4 speakers - 6 feet apart to far?
dman777
I am trying to plan ahead for ordering Cornwall 4 speakers. Would setting them 6 feet apart be to much? I think I would be listening to them about 10 feet away (my couch). Also, since these are directional speakers... assuming the couch (normal 3 person size) is in the middle of the speakers being 6 feet apart, would a chair on the side of the couch be out of the projected soundstage of the speakers?
AudiOhm
London, Ontario, Canada
There is no right/wrong placement, it all depends on room size, seating position, room treatment, etc.
Place them where you think they will sound best, then move them around until YOU like the sound, now you have the correct placement.
I have moved my speakers around a lot, each time I moved them I thought they sounded better.
They are back where I started, who new...
Ohms
MaxwellsEq
If you can get to an equilateral triangle, that's the optimum arrangement (as per standards for listening rooms). Given your arrangement, if anything, the speakers are too close together.
