Comparing different convolution solutions
ppataki
Budapest
While experimenting with various filtering methodologies, for example this:
I started using convolution, concretely Jriver's Convolution engine
I have noticed that it introduces quite a lot of delay that can cause audio/video to get out of sync; especially when using external sources like Youtube, etc.
So I started looking for alternatives - please see below some comparison between them
  • Jriver's Convolution
  • Convology XT
  • SIR3
  • Hofa IQ-Reverb 2
Frequency response using the same wav filter file:
As you can see there is a difference in the level but there is zero difference between the frequency response curves
I could not see any difference in any of the other curves either - please see the measurement file attached for reference; should you notice anything please let me know
Now about the latency, let's play a Youtube video and check delay:
Jriver:
Above 100ms, around 110-120ms
Convology XT:
Around 40-50ms
SIR3:
Very similar, around 40-50ms
HOFA:
This was the lowest, rarely exceeding 40ms
So all in all my conclusion is that I could not find any difference in terms of measurements but there are quite significant differences in terms of delay (especially between Jriver and others)
I add that I also tried ASIO vs WASAPI, the latter resulted in significantly lower latency (using Windows 11 and Topping DM7 DAC)
I hope this helps, please let me know in case of any comments/questions
  • 20220811 REW inverter convolution solutions.zip
ernestcarl
  • Convology XT
  • SIR3
  • Hofa IQ-Reverb 2
Jriver:
Convology XT:
Around 40-50ms
SIR3:
HOFA:
115 ms from JRiver's built-in convolution engine should still be imperceptible with any streaming Youtube AV sync test (after allowing the values to stabilize and/or after a DSP reset). For the DSP and MCH audio interface chain I use, ~200 ms (as shown as the second delay value in 'Audio Path') is my perceptual threshold limit. Only beyond that (e.g. 300+ ms), do I start noticing lip-sync issues.
Convology XT seems not to cost anything at all so I'll try it later.
P
ppataki
Budapest
For me 115ms already presents a totally visible lipsync issue with Youtube (even with 50ms I can see a very little)
So I ditched Jriver's Convolution and using ConvologyXT now (as you also said; it is free of charge + its Normalization feature actually works, unlike Jriver's which is just cutting 6dB)
ernestcarl
Hmmn... something in the software-hardware chain is causing the different results we are seeing. If I were to completely turn off any extra DSP and go back to native 2.0/5.1/7.1 mode, I still see ~110 ms delay -- it cannot go any lower than that number. It's the same result after switching from a multichannel DAC to a plain stereo DAC. There is, of course, no delay noticed with zero additional processing or convolution DSP running in background. Could be my video output is also delayed a bit... Not really sure of the exact cause, but if were true that video is also delayed on my end (I'm no gamer, BTW), I guess that would make it an advantage? :)
