IPunchCholla
- Joined
- Jan 15, 2022
- Messages
- 1,303
- Likes
- 1,735
So I was looking for a lightweight (as in few components) clipping indicator circuit. I came across one on instructables, but now I can't relocate it. The biggest issue with it was it didn't indicate clipping until the output stage came close to the rails of the amplifier. From the measurements presented here, that of course is very far into clipping for most amps. Hype indicates in their data sheet (if I have done the math right) that the 300A1 clipping into 8 ohms happens around 34 volts, while its input rail is +55v. Anyway, I replaced the diodes creating voltage drop in the original circuit with a LM317HV. I am using R6 to put a 50mA pull on the 317HV and R5 is what you would want to use to control the clipping comparator. In the below example I have it setup to compare the incoming signal to that 34v limit.
Everything works fine in simulation. The red in the graph is the incoming output signal from the amp (in this case an attenuating sine wave). The blue line is the regulated voltage. The black line is the current flowing through LED D4 (the clipping indicator). But is this a reasonable way to go about this?
Does anyone here have any favorite universal clipping indicator circuits? In particular I would love ones that measure clipping more directly.
