CDSP V3 beta doesn't start on Fedora 40 (SOLVED); crashes on Win 7
atomant
Hi
Not sure it's the proper place to discuss this. Noticed the beta version and gave it a try.
Code:
$ journalctl --user-unit=camilladsp --user-unit=camillagui -e --no-hostname
oct 15 09:56:35 systemd[2798]: camilladsp.service: Failed with result 'exit-code'.
oct 15 09:56:35 systemd[2798]: Failed to start camilladsp.service - CamillaDSP Service.
oct 15 09:57:10 python3[41144]: ERROR:aiohttp.server:Error handling request
oct 15 09:57:10 python3[41144]: Traceback (most recent call last):
oct 15 09:57:10 python3[41144]:   File "/usr/lib64/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
oct 15 09:57:10 python3[41144]:     resp = await request_handler(request)
oct 15 09:57:10 python3[41144]:            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
oct 15 09:57:10 python3[41144]:   File "/usr/lib64/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
oct 15 09:57:10 python3[41144]:     resp = await handler(request)
oct 15 09:57:10 python3[41144]:   File "/opt/camillagui/backend/views.py", line 401, in get_config_file
oct 15 09:57:10 python3[41144]:     read_yaml_from_path_to_object(request, config_file), config_dir
oct 15 09:57:10 python3[41144]:     ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
oct 15 09:57:10 python3[41144]:   File "/opt/camillagui/backend/filemanagement.py", line 128, in read_yaml_from_path_to_object
oct 15 09:57:10 python3[41144]:     validator.validate_file(path)
oct 15 09:57:10 python3[41144]:   File "/home/shizuma/.local/lib/python3.12/site-packages/camilladsp_plot/validate_config.py", line 186, in validate_file
oct 15 09:57:10 python3[41144]:     self._validate_config()
oct 15 09:57:10 python3[41144]:   File "/home/shizuma/.local/lib/python3.12/site-packages/camilladsp_plot/validate_config.py", line 218, in _validate_config
oct 15 09:57:10 python3[41144]:     self.validate_with_schemas()
oct 15 09:57:10 python3[41144]:   File "/home/shizuma/.local/lib/python3.12/site-packages/camilladsp_plot/validate_config.py", line 255, in validate_with_schem>
oct 15 09:57:10 python3[41144]:     self.validate(self.config["devices"],
oct 15 09:57:10 python3[41144]:                   ~~~~~~~~~~~^^^^^^^^^^^
oct 15 09:57:10 python3[41144]: KeyError: 'devices'
oct 15 09:57:10 python3[41144]:   File "/opt/camillagui/backend/views.py", line 305, in set_config
oct 15 09:57:10 python3[41144]:     config_object = json["config"]
oct 15 09:57:10 python3[41144]:                     ~~~~^^^^^^^^^^
oct 15 09:57:10 python3[41144]: KeyError: 'config'
Am in the process of upgrading the config after perusing https://github.com/HEnquist/camilladsp/compare/v2.0.3...v3.0.0-beta.1
Code:
~/.config/.camilladsp/v3$ diff -ubB ../90deg-surround.yml .
--- ../90deg-surround.yml    2024-10-15 09:22:12.247173449 -0400
+++ ./90deg-surround.yml    2024-10-15 10:49:24.877634476 -0400
@@ -76,42 +76,42 @@
     description: null
     parameters:
       channel: 0
-      filename: ../../rewfiles/CMI8738/7_oct_730hz_fc_lfe_win2-$samplerate$.wav
+      filename: ../../../rewfiles/CMI8738/7_oct_730hz_fc_lfe_win2-$samplerate$.wav
       type: Wav
     type: Conv
   fir_fl:
     description: null
     parameters:
       channel: 0
-      filename: ../../rewfiles/CMI8738/7_oct_730hz_front_win2-$samplerate$.wav
+      filename: ../../../rewfiles/CMI8738/7_oct_730hz_front_win2-$samplerate$.wav
       type: Wav
     type: Conv
   fir_fr:
     description: null
     parameters:
       channel: 1
       type: Wav
     type: Conv
   fir_lfe:
     description: null
     parameters:
       channel: 1
       type: Wav
     type: Conv
   fir_rl:
     description: null
     parameters:
       channel: 0
-      filename: ../../rewfiles/CMI8738/7_oct_730hz_rear_win2-$samplerate$.wav
+      filename: ../../../rewfiles/CMI8738/7_oct_730hz_rear_win2-$samplerate$.wav
       type: Wav
     type: Conv
   fir_rr:
     description: null
     parameters:
       channel: 1
       type: Wav
     type: Conv
   highpass:
@@ -240,14 +240,14 @@
   type: Mixer
 - bypassed: null
-  channel: 0
+  channels: [0]
   description: null
   names:
   - delay_l
   - fir_fl
   type: Filter
 - bypassed: null
-  channel: 1
+  channels: [1]
   description: null
   names:
   - delay_r
@@ -257,14 +257,14 @@
   - fir_fr
   type: Filter
 - bypassed: null
-  channel: 2
+  channels: [2]
   description: null
   names:
   - delay_rl
   - fir_rl
   type: Filter
 - bypassed: null
-  channel: 3
+  channels: [3]
   description: null
   names:
   - delay_rr
@@ -274,14 +274,14 @@
   - fir_rr
   type: Filter
 - bypassed: null
-  channel: 4
+  channels: [4]
   description: null
   names:
   - delay_c
   - fir_fc
   type: Filter
 - bypassed: null
-  channel: 5
+  channels: [5]
   description: null
   names:
   - delay_lfe
After migrating the config I gave it a try on linux and not a sound is getting out of it. Camillagui shows activity on all channels, all in the red though. Something must have been changed with the gain settings.
It's OK, I had to tell pavucontrol to direct the camilla output to the sound card.
Additionally camillagui doesn't understand the new pipeline config.
It's OK, just noticed https://github.com/HEnquist/camillagui-backend/compare/v2.1.1...v3.0.0-beta.4
Code:
$ cat ../camilladsp.log
2024-10-15 11:03:09.610436 INFO  [src/bin.rs:781] CamillaDSP version 3.0.0
2024-10-15 11:03:09.610457 INFO  [src/bin.rs:782] Running on linux, x86_64
2024-10-15 11:03:09.670067 INFO  [src/alsadevice.rs:789] Capture device supports rate adjust
2024-10-15 11:03:09.717634 INFO  [src/alsadevice.rs:117] PB: Starting playback from Prepared state
2024-10-15 11:03:46.084383 WARN  [src/conversions.rs:66] Clipping detected, 243 samples clipped, peak +0.77 dB (109.3%)
2024-10-15 11:03:46.127191 WARN  [src/conversions.rs:66] Clipping detected, 433 samples clipped, peak +1.42 dB (117.8%)
2024-10-15 11:03:46.170635 WARN  [src/conversions.rs:66] Clipping detected, 487 samples clipped, peak +1.84 dB (123.6%)
2024-10-15 11:03:46.255193 WARN  [src/conversions.rs:66] Clipping detected, 558 samples clipped, peak +4.00 dB (158.6%)
Killing the process and restarting CDSP v2 resulted in the mp3 file under test continuing to be played at normal volume level.
Almost there:
Code:
$ systemctl --user status camilladsp camillagui
● camilladsp.service - CamillaDSP Service
     Loaded: loaded (/etc/xdg/systemd/user/camilladsp.service; disabled; preset: disabled)
    Drop-In: /usr/lib/systemd/user/service.d
             └─10-timeout-abort.conf
     Active: active (running) since Tue 2024-10-15 12:40:24 EDT; 7s ago
   Main PID: 240584 (camilladsp3)
      Tasks: 12 (limit: 37191)
     Memory: 20.4M (peak: 20.8M)
        CPU: 674ms
     CGroup: /user.slice/user-1000.slice/[email protected]/app.slice/camilladsp.service
             └─240584 /usr/local/bin/camilladsp3 -p1234 -w -o /home/shizuma/.config/.camilladsp/camilladsp.log -s /home/shizuma/.config/.camilladsp/statefile.y>
oct 15 12:40:24 shizuma systemd[2885]: Started camilladsp.service - CamillaDSP Service.
● camillagui.service - CamillaDSP Backend and GUI
     Loaded: loaded (/etc/xdg/systemd/user/camillagui.service; disabled; preset: disabled)
   Main PID: 240585 (python3)
      Tasks: 1 (limit: 37191)
     Memory: 34.0M (peak: 34.5M)
        CPU: 703ms
     CGroup: /user.slice/user-1000.slice/[email protected]/app.slice/camillagui.service
             └─240585 /usr/bin/python3 /opt/camillaguiv3/main.py
oct 15 12:40:32 shizuma python3[240585]:   File "/usr/lib64/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
oct 15 12:40:32 shizuma python3[240585]:     resp = await request_handler(request)
oct 15 12:40:32 shizuma python3[240585]:            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
oct 15 12:40:32 shizuma python3[240585]:   File "/usr/lib64/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
oct 15 12:40:32 shizuma python3[240585]:     resp = await handler(request)
oct 15 12:40:32 shizuma python3[240585]:   File "/opt/camillaguiv3/backend/views.py", line 166, in get_param
oct 15 12:40:32 shizuma python3[240585]:     result = cdsp.volume.main_mute()
oct 15 12:40:32 shizuma python3[240585]: AttributeError: 'Volume' object has no attribute 'main_mute'
End of test. Install successful.
Crashes on Windows 7.
That's all the info I could gather:
Willing to do any test you might find useful.
